Bug: Have to press Search twice
Server Version#: 1.19.5.3035
Player Version#: 3.1.1
In Windows 10, When I click the Magnifying Glass to search in Plexamp, I cannot immediately start typing. I must then click on the search input field on the top before I can begin typing. Is this the expected behavior or is this a bug?
By design—first click focuses the tab so that you can select an aural fixation or recent search. Second click focuses search input.
@nhasian if this is the bug you were referring to in the how to thread, i clearly state this functionality in the Search section
Search Bar Focus - Selecting the Search Tab at the bottom will change over to the Search screen. Upon first display Aural Fixations and Recent Searches will be displayed while the search bar is at the top. To begin searching, clicking in the search box will change focus to the search box along with a cursor (and keyboard popup if on mobile/touch). If you don’t want to be bothered having to click IN the search box, simply click/select the search tab at the BOTTOM again and focus will change to the search box.
Was this wording confusing? I can reword it, please let me know, i want to make it clear on functionality.
Hello Sekthree,
Thanks for your response. If that is by design then I’ll just click on the magnifying glass twice. I just thought it would be easier to start typing for the search results.
