I stream from PMS (running on Synology) to a variety of platforms including the nVidia Shield TV. The Shield TV has some issues supporting E-AC3 audio, so playing files with E-AC3 audio triggers an audio transcode. That’s good, no problem with that. However, unexpected behaviour occurs when the video is also HEVC.
H.264 + E-AC3 audio → Video direct streams, audio transcodes (expected)
HEVC + AAC audio → Video direct streams, audio direct streams (expected)
HEVC + E-AC3 audio → Video transcodes, audio transcodes (unexpected video transcode)
What I don’t understand is why in the third case, the video transcodes as well as the audio.
The issue I am reporting here seems to have been reported by another user a year ago:
https://forums.plex.tv/t/why-does-hevc-video-transcode-to-h264-when-audio-is-transcoding-eac3-aac-direct-stream-expected/618627
As with the above report, this happens with subtitles turned on or off and regardless of subtitle burn-in settings.
If I turn off video transcoding (which I don’t want to do, but just to test) then the file will refuse to play. Media playback info says the reason for transcoding is just E-AC3 audio is not supported; no comment on why the video is transcoding.
So, first, I wanted to report the bug. But also wanted to inquire if it was possible to tell Plex to play the video directly. Nothing about the video in this case requires transcoding. Any ideas?
