Hi, I am using Nvidia shield 2019 Pro with latest Plex androidTV beta 8.7.0.20568, and for shows I am currently watching I cannot mark all season of a currently watching showing as Played. I would go the to next episode and from there I would select the triple dots menu and select “Go to show”. Then select the “Mark as Played” option and get an error saying “there was an error and check your internet connection to the media server” my internet connection is fine as I can continue to watch.
Same on Sony Bravia Android TV.
Just checked on version 8.7.0.20759-beta, and the bug is there present.
Same here on sony Bravia atv3 running plex app 8.7.2.20952
Can confirm same bug for me on current build, can’t mark whole show or I think series as played, does nothing, no error given, just does nothing.
I have tested with the latest beta on Android tv, and still cannot mark as show as played when going into a show and click mark as played (between play and more buttons)
@marekszulik since you were able to help with the Playlist issue, can you help with this bug too?
Funny you should ask that now. I’ve worked on it this week and the fix is available in the latest beta v8.11.0.22093.
Updated and tested it out. The newest beta fixed this issue.
