Server Version#: 1.21.1.3876
Player Version#: 4.49.2?
Steps:
- Create new playlist or edit existing (edit filters).
- Create item “title” “contains” “Will & Grace” (note that contains can be begins with or ends with, whatever) and title can be any text field value. The value can be “D&D” or “Beavis & Butthead”, etc.
- Save
- Edit Saved Playlist
- Playlist will now read “title” “contains” "Will " and the contents will reflect that filter, loosing the “& Grace”
This isn’t cured with Will & Grace, but of does leave you with "Will " also. So there is a double encoding issue of some sort it would seem.
