Server Version#: 4.100.1
Player Version#: 4.6.3
Plexamp on my iPhone 13 Pro (all latest updates) freezes when I search and then select a search result. For instance, I search “Tristessa” and then click on the song in the results, for a split second I see the slide-over which shows Play, Play Track Radio, Play Next, Add to Queue, etc… but it disappears immediately and all I see is the search results except now the entire interface is frozen. Tapping anywhere in the app has no effect.
However sometimes if I wait about 30-60 seconds then tap in random areas of the screen, the slide-over reappears, I can select Play, and the app continues to work normally. Other times the app stays in this frozen state. I have force quit the app and it makes no difference. This bug is repeatable 100% of the time. It does not matter if I’m listening to Airpods, streaming to an Airplay endpoint, or using CarPlay.
