Anyone else having an issue with Plexamp on iPhone. It loads correct the first time but when I try to use it again a few hours later the app freezes on a blank home page. I need to uninstall and reinstall constantly to get it to work but same issue happens each time. Using iOS 14.7.1 and app version 3.5.0 on iPhone XS.
I’ve never seen that.
Though… you can probably get it back to work by force-quitting the app and restarting it – there should be no need to reinstall from scratch.
Hi Tom80H,
Unfortunately force quitting the app does not make any difference, it freezes on relaunch. A fresh install is require to reset each time.
Could you please share your Plexamp’s logs?
Settings > Advanced > Debugging > Share Logs
Plexamp-Logs-2021-09-02-4.zip (16.0 KB)
Hi Tom80H,
Most recent log from fresh install earlier today attached. Hope you can see what’s wrong from this.
I think I might see the issue. Any chance you have a truly massive music library? If so, how many artists/albums/tracks?
Should be fixed in the next release
Hi Elan,
Yes my library is very large. Hopefully the next fix solves this issue so, looking forward to the fix.
Thanks.
I think “large” is a building or even a city. Your library must be the size of a small planet
Hi Elan,
The update today has fixed my crash issue. All working well again. Thanks for the help.
Great, glad to hear it!
