Since version 1.1 of PMS , all my video files get misidentified audio track therefore I cant transcode them for iPhone or iPad.
PMS 0.9.16 identifies correctly the audio - hence i’m stuck with that version for ages now.
MediaInfo and VLC identify the audio track as MPEG2 (correctly) while PMS v.1.33 thinks it’s mp3 (false) and it tries to directplay to iPhone and iPad ( which obviously doesnt work as iOS doesnt support MPEG2 Audio )
Example File here
https://drive.google.com/file/d/0B2pLkasbefjMWm9xeDAwYnNSMFk/view?usp=sharing
MediaInfo (audio track identified as MPEG2):
<?xml version="1.0" encoding="UTF-8"?>
<Mediainfo version="0.7.89">
<File>
<track type="General">
<CompleteName>Z:\recorded_tv\ScoobyDoo Mecha Mutt Menace\2016\ScoobyDoo Mecha Mutt Menace 03291600.mp4</CompleteName>
<Format>MPEG-4</Format>
<Format_Profile>Base Media</Format_Profile>
<CodecID_String>isom (isom/iso2/mp41)</CodecID_String>
<FileSize_String>872 MiB</FileSize_String>
<Duration_String>32 min 41 s</Duration_String>
<OverallBitRate_Mode_String>Variable</OverallBitRate_Mode_String>
<OverallBitRate_String>3 731 kb/s</OverallBitRate_String>
<Season>2016</Season>
<Movie> (Tue, Mar 29)</Movie>
<Genre>Boomerang</Genre>
<ContentType>TV Show</ContentType>
<Recorded_Date>2016-3-29</Recorded_Date>
<Tagged_Date>UTC 2016-03-29 14:34:28</Tagged_Date>
<Encoded_Application_String>Scooby-Doo! Mecha Mutt Menace</Encoded_Application_String>
<Copyright>Season 2016</Copyright>
<LongDescription>The gang visits a Science Expo and find a revolutionary remote-controlled lunar rover, resembling a large dog, is out of control.</LongDescription>
</track>
<track type="Video">
<ID_String>2</ID_String>
<Format>MPEG Video</Format>
<Format_Version>Version 2</Format_Version>
<Format_Profile>Main@Main</Format_Profile>
<Format_Settings_BVOP_String>Yes</Format_Settings_BVOP_String>
<Format_Settings_Matrix_String>Custom</Format_Settings_Matrix_String>
<Format_Settings_GOP>Variable</Format_Settings_GOP>
<Format_Settings_PictureStructure>Frame</Format_Settings_PictureStructure>
<CodecID>61</CodecID>
<Duration_String>32 min 40 s</Duration_String>
<BitRate_Mode_String>Variable</BitRate_Mode_String>
<BitRate_String>3 535 kb/s</BitRate_String>
<BitRate_Maximum_String>15.0 Mb/s</BitRate_Maximum_String>
<Width_String>544 pixels</Width_String>
<Height_String>576 pixels</Height_String>
<DisplayAspectRatio_String>16:9</DisplayAspectRatio_String>
<DisplayAspectRatio_Original_String>16:9</DisplayAspectRatio_Original_String>
<FrameRate_Mode_String>Variable</FrameRate_Mode_String>
<FrameRate_String>24.896 FPS</FrameRate_String>
<FrameRate_Minimum_String>0.123 FPS</FrameRate_Minimum_String>
<FrameRate_Maximum_String>90 000.000 FPS</FrameRate_Maximum_String>
<FrameRate_Original_String>25.000 FPS</FrameRate_Original_String>
<ColorSpace>YUV</ColorSpace>
<ChromaSubsampling_String>4:2:0</ChromaSubsampling_String>
<BitDepth_String>8 bits</BitDepth_String>
<ScanType_String>Interlaced</ScanType_String>
<ScanOrder_String>Top Field First</ScanOrder_String>
<Compression_Mode_String>Lossy</Compression_Mode_String>
<Bits_Pixel_Frame_>0.453</Bits_Pixel_Frame_>
<StreamSize_String>826 MiB (95%)</StreamSize_String>
</track>
<track type="Audio">
<ID_String>1</ID_String>
<Format>MPEG Audio</Format>
<Format_Version>Version 1</Format_Version>
<Format_Profile>Layer 2</Format_Profile>
<CodecID>6B</CodecID>
<BitRate_Mode_String>Constant</BitRate_Mode_String>
<BitRate_String>192 kb/s</BitRate_String>
<Channel_s__String>2 channels</Channel_s__String>
<SamplingRate_String>48.0 kHz</SamplingRate_String>
<StreamSize_String>44.7 MiB (5%)</StreamSize_String>
<Language_String>English</Language_String>
<Default_String>Yes</Default_String>
<AlternateGroup_String>1</AlternateGroup_String>
</track>
</File>
</Mediainfo>
Plex v0.9.16 (audio track identified as MPEG2):
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="15" librarySectionTitle="TV" librarySectionUUID="83c464e8-5d2b-44bf-bc94-e4273bb49f00" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1461326894">
<Video ratingKey="81431" key="/library/metadata/81431" parentRatingKey="81430" grandparentRatingKey="81429" guid="com.plexapp.agents.none://81429/2016/1?lang=xn" librarySectionID="15" type="episode" title=" (Tue, Mar 29)" titleSort="Tue, Mar 29)" grandparentKey="/library/metadata/81429" parentKey="/library/metadata/81430" grandparentTitle="Scoobydoo Mecha Mutt Menace" summary="The gang visits a Science Expo and find a revolutionary remote-controlled lunar rover, resembling a large dog, is out of control." index="1" parentIndex="2016" year="2016" thumb="/library/metadata/81431/thumb/1483558454" art="/library/metadata/81429/art/1483558454" parentThumb="/library/metadata/81430/thumb/1483558454" grandparentThumb="/library/metadata/81429/thumb/1483558454" grandparentArt="/library/metadata/81429/art/1483558454" duration="1961136" originallyAvailableAt="2016-03-29" addedAt="1459262074" updatedAt="1483558454" chapterSource="">
<Media videoResolution="480" id="128727" duration="1961136" bitrate="3731" width="544" height="576" aspectRatio="1.78" audioChannels="2" audioCodec="mp2" videoCodec="mpeg2video" container="mp4" videoFrameRate="PAL" optimizedForStreaming="1" has64bitOffsets="0" videoProfile="main">
<Part accessible="1" exists="1" id="129138" key="/library/parts/129138/file.mp4" duration="1961136" file="E:\recorded_tv\ScoobyDoo Mecha Mutt Menace\2016\ScoobyDoo Mecha Mutt Menace 03291600.mp4" size="914529375" container="mp4" has64bitOffsets="0" optimizedForStreaming="1" videoProfile="main">
<Stream id="198281" streamType="1" default="1" codec="mpeg2video" index="1" bitrate="3535" anamorphic="1" bitDepth="8" chromaSubsampling="4:2:0" codecID="61" colorRange="tv" duration="1960760" frameRate="24.896" frameRateMode="vfr" height="576" pixelAspectRatio="32:17" pixelFormat="yuv420p" profile="main" scanType="interlaced" streamIdentifier="2" width="544"/>
<Stream id="198280" streamType="2" selected="1" default="1" codec="mp2" index="0" channels="2" bitrate="192" language="English" languageCode="eng" audioChannelLayout="stereo" bitrateMode="cbr" codecID="6B" duration="1961136" samplingRate="48000" streamIdentifier="1"/>
</Part>
</Media>
<Extras size="0"></Extras>
</Video>
</MediaContainer>
Plex v1.33 (audio track identified as MP3 -> wrong):
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="3" librarySectionTitle="Movies" librarySectionUUID="62075288-1945-4778-bfdb-39257fc03c3f" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1481837822">
<Video ratingKey="1425" key="/library/metadata/1425" guid="com.plexapp.agents.none://95974689b10e964d87a722c1983160b225f6dc43?lang=xn" librarySectionID="3" studio="Season 2016" type="movie" title="ScoobyDoo Mecha Mutt Menace 03291600" summary="The gang visits a Science Expo and find a revolutionary remote-controlled lunar rover, resembling a large dog, is out of control." year="2016" thumb="/library/metadata/1425/thumb/1483823547" art="/library/metadata/1425/art/1483823547" duration="1961136" originallyAvailableAt="2016-03-29" addedAt="1459262074" updatedAt="1483823547" createdAtAccuracy="epoch" createdAtTZOffset="-25200">
<Media videoResolution="480" id="1184" duration="1961136" bitrate="3731" width="544" height="576" aspectRatio="1.78" audioChannels="2" audioCodec="mp3" videoCodec="mpeg2video" container="mp4" videoFrameRate="PAL" optimizedForStreaming="1" has64bitOffsets="0" videoProfile="main">
<Part accessible="1" exists="1" id="1184" key="/library/parts/1184/1459262074/file.mp4" duration="1961136" file="Z:\recorded_tv\ScoobyDoo Mecha Mutt Menace\2016\ScoobyDoo Mecha Mutt Menace 03291600.mp4" size="914529375" container="mp4" deepAnalysisVersion="2" has64bitOffsets="0" optimizedForStreaming="1" requiredBandwidths="3731,3731,3731,3731,3731,3731,3731,3731" videoProfile="main">
<Stream id="1948" streamType="1" default="1" codec="mpeg2video" index="1" bitrate="3535" anamorphic="1" bitDepth="8" chromaSubsampling="4:2:0" colorRange="tv" frameRate="24.896" height="576" level="8" pixelAspectRatio="32:17" profile="main" refFrames="1" requiredBandwidths="3541,3541,3541,3541,3541,3541,3541,3541" streamIdentifier="2" width="544"/>
<Stream id="1947" streamType="2" selected="1" default="1" codec="mp3" index="0" channels="2" bitrate="191" language="English" languageCode="eng" audioChannelLayout="stereo" requiredBandwidths="192,192,192,192,192,192,192,192" samplingRate="48000" streamIdentifier="1"/>
</Part>
</Media>
<Genre id="9" tag="Boomerang"/>
</Video>
</MediaContainer>
but for now version 0.9.16.6 works like a treat.
