Bug report: Plexamp crashes with strict sample rate matching (macOS)
Plexamp Version#: 4.4.0
OS: macOS
Plexamp crashes when you skip tracks quickly if sample rate matching is turned on and the tracks have different sample rates. This error was introduced with version 4.4.0. Previous versions didn’t have this problem.
I guess if you interrupt the process of Plexamp switching the sample rate by quickly skipping to the next song (with again a different sample rate), they get in each other’s way and throw an error.
So maybe just block the skip buttons during the switching process or make it async somehow?
Crash report:
Plexamp Helper (Renderer)-2022-09-22-213957.txt (56.8 KB)
Btw: Is strict sample rate matching coming to other OS’s like Android? :slight_smile:
Thanks very much for the report, should be fixed in the next release.
