No gapless playback on iOS
On iOS 27b7 and plexamp 4.50.7
Tried a couple of albums and there is no gapless playback.
Using downloaded Flac files.
Some specific options I’m meant to turn on ?
Issue appears to happen when I have ‘sample rate matching’ in ‘Strict’ mode.
If I put it to ‘Smart’ I get correct gapless playback.
Switching of sample rate between tracks does prevent gapless playback.
You can’t have both.
Even if the tracks the same rate ?
Unfortunately yes. The code paths are different.
Either you have sweet fades working always, or never.
ah good to know, thanks
if the tracks are the same rate then there shouldn’t be pause between them.
if you provided logs we could help you
Plexamp-Logs-2026-09-06-1.zip (291.1 KB)
Logs attached.
I went to a track, moved to near the end of the track and was gapless when in Smart.
Then went to strict, repeated above and wasn’t gapless.
