[Bug] Setting Plex to TV mode, some filters are unselectable.
Pretty much as the title says. It is present across the platform Music, TV Movies…
I would expect one to be able to, for instance Select unwatched in the movie section, and sort by other methods, or in music search genres, etc.
This is in the wrong section. This subforum is for the Android TV client found on SHIELD and other TV that have Android TV. The TV mode you speak of is found on the MOBILE android client. You want the other forum. Android Mobile. As confusing as that is haha.
Feel free to move it, it’s a bug in the beta android TV client, regardless.
Are you experiencing the problem on SHIELD / Android TV as well? It’s completely different to the mobile tv mode…
The device has a RK3288 chipset and it runs Android 5.1. Should I still post in another section?
I would personally would as that’s not Android TV as such. It’s just android with a tv interface. This wouldn’t be the right place for that whereas the beta section for the mobile app is the client you are using.
Thanks for your time, and advice. I’ve reposted here:
