[BUG] Stream is closed while streaming with Plex token. Why?
Server Version: 1.32.5.7328
Player Version: VLC or Kodi
Hello everyone i have an kodi app that use the http with the token in parameters so it can open my streams on my old enigma2 receiver.
Btw the stream stop after i launch a 2nd stream for no real reason.
Here is the logs:
Jul 22, 2023 04:44:39.441 [140624374291256] DEBUG - Request: [xxx.xxx.xxx.xx:47380 (WAN)] GET /library/parts/193697/1609103323/file.mkv (15 live) #71dcd7 Signed-in Token ( Prod) (XUI) (range: bytes=23724158-) / Accept => / / Accept-Language => fr / Host => xxx.xxx.xxx.xx:31766 / If-Match => “f670ce303d1ff836d6509075aa9a87b90dd77ee7” / Range => bytes=23724158- / User-Agent => VLC/3.0.17.3 LibVLC/3.0.17.3 / X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Jul 22, 2023 04:44:39.558 [140624374291256] DEBUG - [Req#71dcd7] Streaming Resource: Terminating session 0x7fe5a914e948:token=xxxxxxxxxxxxxxxxxxxx which is using 8976kbps of WAN bandwidth. Used is now 0kbps
Jul 22, 2023 04:44:39.559 [140624374291256] DEBUG - [Req#71dcd7] Streaming Resource: Terminated session 0x7fe5a914e948:token=xxxxxxxxxxxxxxxxxxxx with reason Client stopped playback.
Jul 22, 2023 04:44:39.559 [140624374291256] DEBUG - [Req#71dcd7] Streaming Resource: Removing session 0x7fe5a914e948:token=xxxxxxxxxxxxxxxxxxxx
Jul 22, 2023 04:44:39.559 [140624374291256] DEBUG - [Req#71dcd7] Streaming Resource: Attempting to create AdHoc dp session for part 193697
Jul 22, 2023 04:44:39.563 [140624374291256] DEBUG - [Req#71dcd7] TranscodeUniversalRequest: using profile Generic
Jul 22, 2023 04:44:39.563 [140624374291256] DEBUG - [Req#71dcd7] Downloading document http://127.0.0.1:32400/library/metadata/108391?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=token%3DCnxg_yL1rxzPArQyyb_K
Jul 22, 2023 04:44:39.563 [140624374291256] DEBUG - [Req#71dcd7/HCl#9a9] HTTP requesting GET http://127.0.0.1:32400/library/metadata/108391?X-Plex-
Tautulli doesn’t have any script running i double checked it, and the stop after x pause time minutes is set to 0.
CPU 4 Cores.
Ram : 16 Gb
Ubuntu 20.04
Any help on throubleshoting this ?
Is this a know issue on plex forum ?
This is how url is oppened according to my diagnosis.
http://xxx.xxx.xxx.xxx:31766/library/parts/138085/1629993100/file.mkv?X-Plex-Token=xxxxxx_xxxxx_xxx
I also have plenty of those errors.
