Plex Media Server Logs_2022-11-06_17-52-37.zip (6.9 MB)
Server Version#: 1.29.1.6316
Player Version#: 9.10.1.36024
Playback stops after a short period of time as if the episode has fished. Plex then goes to play the next episode.
I have this problem on my android-tv. The stream begins and then after a short period of time (<2m) the stream ends and then auto-plays the next episode in the series.
This occurs for different types of content:
What I have tested as working:
What I tested that does not work:
From the OP’s server log I see this:
Nov 06, 2022 17:52:11.988 [0x7ff6324a6b38] DEBUG - Failed to stream media, client probably disconnected after 442368 bytes: 32 - Broken pipe
My error message is the same in my server log:
Nov 29, 2022 14:19:10.377 [0x7ff5dd921b38] DEBUG - Failed to stream media, client probably disconnected after 16384 bytes: 32 - Broken pipe
I also have the logs for the Plex Android TV client. Here is a snippet.
11-29 14:19:04.138 i: [FFmpegExtractor] Interrupting extractor for release.
11-29 14:19:04.139 i: [FFmpegExtractor] Extractor has been released.
11-29 14:19:04.140 i: [FFmpeg] [INFO] [FFmpegExtractor] Reading whilst closed, exiting.
11-29 14:19:04.141 i: [FFmpeg] [WARN] [CacheSource] Encountered result whilst reading from source at 10522710 bytes: Immediate exit requested (-1414092869).
11-29 14:19:04.141 i: [FFmpeg] [WARN] [CacheSource] Source or buffer is still interrupted.
11-29 14:19:04.142 i: [FFmpeg] [INFO] [CacheSource] Thread has been terminated.
11-29 14:19:04.142 i: [FFmpeg] [INFO] [FFmpegExtractor] Closing demuxer context.
11-29 14:19:04.143 i: [FFmpeg] [INFO] [CacheSource] Close requested, terminating.
11-29 14:19:04.143 i: [FFmpeg] [INFO] [CacheSource] Terminating thread.
11-29 14:19:04.144 i: [FFmpeg] [INFO] [FFmpegExtractor] Source has been closed successfully.
11-29 14:19:04.144 i: [FFmpeg] [INFO] [CacheSource] Closed successfully.
11-29 14:19:04.145 e: [ExoPlayer][EventLogger] playerFailed [eventTime=46.93, mediaPos=8.49, window=0, period=0, errorCode=ERROR_CODE_IO_NETWORK_CONNECTION_TIMEOUT
com.google.android.exoplayer2.r: Source error
at com.google.android.exoplayer2.w1.G(SourceFile:17)
at com.google.android.exoplayer2.w1.handleMessage(SourceFile:295)
at android.os.Handler.dispatchMessage(Handler.java:103)
at android.os.Looper.loop(Looper.java:214)
at android.os.HandlerThread.run(HandlerThread.java:67)
Caused by: y4.b0: java.net.SocketTimeoutException: timeout
at y4.u.b(SourceFile:266)
at y4.t.b(SourceFile:161)
at y4.p0.b(SourceFile:13)
at com.google.android.exoplayer2.source.r0$a.load(SourceFile:26)
at y4.i0$d.run(SourceFile:52)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
at java.lang.Thread.run(Thread.java:919)
Caused by: java.net.SocketTimeoutException: timeout
at com.android.okhttp.okio.Okio$3.newTimeoutException(Okio.java:214)
at com.android.okhttp.okio.AsyncTimeout.exit(AsyncTimeout.java:263)
at com.android.okhttp.okio.AsyncTimeout$2.read(AsyncTimeout.java:217)
at com.android.okhttp.okio.RealBufferedSource.indexOf(RealBufferedSource.java:307)
at com.android.okhttp.okio.RealBufferedSource.indexOf(RealBufferedSource.java:301)
at com.android.okhttp.okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:197)
at com.android.okhttp.internal.http.Http1xStream.readResponse(Http1xStream.java:188)
at com.android.okhttp.internal.http.Http1xStream.readResponseHeaders(Http1xStream.java:129)
at com.android.okhttp.internal.http.HttpEngine.readNetworkResponse(HttpEngine.java:750)
at com.android.okhttp.internal.http.HttpEngine.readResponse(HttpEngine.java:622)
at com.android.okhttp.internal.huc.HttpURLConnectionImpl.execute(HttpURLConnectionImpl.java:475)
at com.android.okhttp.internal.huc.HttpURLConnectionImpl.getResponse(HttpURLConnectionImpl.java:411)
at com.android.okhttp.internal.huc.HttpURLConnectionImpl.getResponseCode(HttpURLConnectionImpl.java:542)
at com.android.okhttp.internal.huc.DelegatingHttpsURLConnection.getResponseCode(DelegatingHttpsURLConnection.java:106)
at com.android.okhttp.internal.huc.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:30)
at y4.u.u(SourceFile:98)
at y4.u.b(SourceFile:13)
... 7 more
Caused by: java.net.SocketException: socket is closed
at com.android.org.conscrypt.ConscryptFileDescriptorSocket$SSLInputStream.read(ConscryptFileDescriptorSocket.java:554)
at com.android.okhttp.okio.Okio$2.read(Okio.java:138)
at com.android.okhttp.okio.AsyncTimeout$2.read(AsyncTimeout.java:213)
... 21 more
Any help would be appreciated to see if there is some way to make steaming video work once again. The Plex app for Android TV has had about a one-year outage for streaming video. It did work previously.
A new firmware version was released for my Asus router. After the upgrade Plex now plays videos again. This makes it seem like this networking timeout was caused by the router.
