BUG: When controller is turned on when launching Plex HTPC, controller will not work in app
Hi all!
Just set up Plex HTPC, added it to my frontend game launcher, set up the input mapping, and all’s well and good- so long as the controller is off before launching Plex HTPC. If it’s on, the controller will do no good in the application itself.
This is preventing me from using Plex HTPC in a console-like environment, where I can use a controller to do everything. Instead, I still need to have a keyboard and mouse handy to navigate the app.
Is there any plan to remedy this issue? Seems fairly useless to have to ensure that a controller is disconnected/off before using the app.
Thanks!
This has been a bug for a while, I just gave up on using a controller.
