Bug with playback
So i have been getting this weird issue fo playback for a while now. it will randomly stop playing and just load. the ONLY way to get it to play again is to completely close out of the tabs and reopen everything. I usually use a pc inside the network with the web app. th issue is random so the logs are long. some days it does it more than others. This time i could only replicate it twice. 1 time on the initial try to play media and then a little later in.
server version 1.32.7.7621 but has done it on previous versions.
using
Plex Media Server Logs_2023-11-13_21-34-14.zip (3.8 MB)
windows 11 64 bit
Do you experience the same behavior using the desktop app (e.g. Plex for Windows / Plex HTPC)?
I’ve never used the desktop app. I’ve gotten to used to the web player.
