Server Version#: Version 1.28.2.6151
Player Version#: Version 4.90.1
I’d like to build a smart playlist based off track ratings. Sounds simple enough, but I also don’t want the same track to appear more than once.
Take this scanario:
As a test rate one single track you know is in multiple albums on your plex server, just rate one. In this example, Piano Man from Billy Joel which is in 4 different albums.
Now create a advanced filter to find all tracks with that rating.
Result:
It finds the track from all albums, due to the track ID I guess which is in my music tags.
For all I know you cannot achieve that.
It seems a bit off as Plex elsewhere treats them the same (e.g. same rating is automatically applied – as per your example).
As for your very specific question / use case: you can always set Limit To to 1
Thanks tom for the reply. The Limit To in the advanced filter is meant to limit the total number of tracks and it does not limit the resulting tracks when multiple of the same track are found.
Example below …
Rate three tracks I know are in multiple albums on your plex server. These are Piano Man, Updown Girl & We Didn’t Start the Fire all from Billy Joel.
In a smart playlist this finds 11 tracks.
Now when I change the Limit To to 1 it now filters to 1 track and not the 3.
Anyhow, sounds like what I want is not possible. I’ll look to see if I can do something else, what I’m not sure! The fact I cannot search or sort a normal playlist is a huge pain in the neck for curating large playlists.
What I’m looking for really is a secondary filter – 1) find all tracks with 5 stars and 2) don’t give me any duplicates based on the first set of results.
This certainly helps but is not perfect as I’ll need to make sure everything I want is not in a compilation.
Anyhow, I’m going to create a feature request to see if Duplicate could be added for tracks so we could search and return 1 resulting track when multiple exist on a server.
