hi guys,
after following the guide at http://wiki.plexapp.com/index.php/How_to_C…ilding_the_Code i’m encountering the following build error:
[codebox]/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:481: error: integer constant is too large for ‘long’ type
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:483: error: integer constant is too large for ‘long’ type
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:530: error: integer constant is too large for ‘long’ type
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:538: error: integer constant is too large for ‘long’ type
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:635: error: integer constant is too large for ‘long’ type
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:637: error: integer constant is too large for ‘long’ type
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:647: error: integer constant is too large for ‘long’ type
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:649: error: integer constant is too large for ‘long’ type
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:669: error: integer constant is too large for ‘long’ type
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:673: error: integer constant is too large for ‘long’ type
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:680: error: integer constant is too large for ‘long’ type
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:681: error: integer constant is too large for ‘long’ type
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:771: error: integer constant is too large for ‘long’ type
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:817: error: integer constant is too large for ‘long’ type
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:832: error: integer constant is too large for ‘long’ type
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:946: error: integer constant is too large for ‘long’ type
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp: In member function ‘virtual void CDVDDemuxFFmpeg::Flush()’:
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:481: error: ‘INT64_C’ was not declared in this scope
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp: In member function ‘double CDVDDemuxFFmpeg::ConvertTimestamp(int64_t, int, int)’:
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:530: error: ‘INT64_C’ was not declared in this scope
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:538: error: ‘INT64_C’ was not declared in this scope
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp: In member function ‘virtual DemuxPacket* CDVDDemuxFFmpeg::Read()’:
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:635: error: ‘INT64_C’ was not declared in this scope
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:637: error: ‘INT64_C’ was not declared in this scope
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:647: error: ‘INT64_C’ was not declared in this scope
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:649: error: ‘INT64_C’ was not declared in this scope
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:669: error: ‘INT64_C’ was not declared in this scope
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp: In member function ‘virtual bool CDVDDemuxFFmpeg::SeekTime(int, bool, double*)’:
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:771: error: ‘INT64_C’ was not declared in this scope
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp: In member function ‘void CDVDDemuxFFmpeg::UpdateCurrentPTS()’:
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:817: error: ‘INT64_C’ was not declared in this scope
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp: In member function ‘virtual int CDVDDemuxFFmpeg::GetStreamLength()’:
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:832: error: ‘INT64_C’ was not declared in this scope
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp: In member function ‘void CDVDDemuxFFmpeg::AddStream(int)’:
/Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp:946: error: ‘INT64_C’ was not declared in this scope
PhaseScriptExecution /Users/lankz/Workspace/Plex/plex/build/Plex.build/Debug/Plex.build/Script-E3AC021F0E3B34FA00DD298E.sh
cd /Users/lankz/Workspace/Plex/plex
/bin/sh -c /Users/lankz/Workspace/Plex/plex/build/Plex.build/Debug/Plex.build/Script-E3AC021F0E3B34FA00DD298E.sh
** BUILD FAILED **
The following build commands failed:
Plex:
CompileC build/Plex.build/Debug/Plex.build/Objects-normal/i386/DVDDemuxFFmpeg.o /Users/lankz/Workspace/Plex/plex/xbmc/cores/dvdplayer/DVDDemuxers/DVDDemuxFFmpeg.cpp normal i386 c++ com.apple.compilers.gcc.4_2
(1 failure)[/codebox]
i’ve seen the same error(s) mentioned at http://forums.plexapp.com/index.php?showtopic=818 but not much in the ways of a solution
same error for v0.5 and v0.7 from elans repo. latest xcode.
any advice appreciated
