Would this be enough cpu power to run 2 4k movies at the sametime locally and some transcoding AMD Ryzen 7 3700X 8-Core, 16-Thread Unlocked Desktop Processor with Wraith Prism LED Cooler
or AMD Ryzen 9 3900X 12-core, 24-Thread Unlocked Desktop Processor with Wraith Prism LED Cooler
And 32 ram and linux the server gonna be seprate I guess no graphic card since I dont need one ?
Assuming the worst case scenario that the media will be h.265(HEVC) and you won’t be using a Nvidia Shield wired to an AVR wired to the TV, thus no direct play.
h.265 and future decoding is best performed by discrete chips present on GPU’s.
I use an i7 8700 for my server (Debian 10), not so far from your Rizen. My values for only one 4K transcoding at the same time:
Software transcoding
CPU: 90%
Audio out of sync: sometimes for high bitrate files
Image freezes: no
Hardware transcoding:
CPU: 20%
Image freezes: yes - about one every 3 minutes
I disabled hardware transcoding due to image freezes and I re-encode now my files to prevent software transcoding which is just too high about consumption.
This is not power related.
You can just cross fingers it will work with your config but my message is to warm you that your project can fail.
I expected a lot of issues last weeks/monts starting to transcode 4k. Last example: I cannot start a 4K movie on a 1080P TV, I have directly a message that informs me that the connection to the server has been lost. If I start a 1080P movie, there is no error message anymore…
