Building RasPlex from source for RPi1 & RPi2
I'm building RasPlex 0.6.0 from source because I see in a later commit VPN support was added back in, however, how do I build an image for RPi1 then another image for RPi2? I'm not sure what changes need to be made to do that. Can someone assist?
Nevermind I just had to edit the buildman script and change PROJECT=RPi to PROJECT=RPi2.
You will not get VPN back if you build 0.6.0, it's back in the next release.
I'm actually building rasplex-dev-0.6.X. https://github.com/RasPlex/OpenELEC.tv/commit/3dfaec1d819a9a1208db526c46f3346c94c03981
Ok so every time I try and build from source it fails. I've followed https://github.com/RasPlex/RasPlex/wiki/Native-development-environment-setup and when I go into the OpenELEC.tv directory and run './buildman -t RP-0.6.0 -r -l -f -i' it gets almost all the way through but fails at compiling a part of Kodi. I also noticed that when I run the buildman script that the working directory doesn't change at all meaning that it doesn't checkout the RP-0.6.0 tag?
root@dev:~/RasPlex/OpenELEC.tv# git tag | grep RP-0.6.0
RP-0.6.0
root@dev:~/RasPlex/OpenELEC.tv# git branch
* (detached from 629d623)
  rasplex-dev-0.6.X
What am I doing wrong?
RP-0.6.0
rasplex-dev-0.6.X
Probably because the dev branches of Rasplex 0.6.0 are still private and will be until 0.6.0 is released as stable, currently it is still pre-release.
Ugh, that makes more sense. I just wanted to build a new image with PPTP support for RPi2. The 0.5.1 image isn't stable. :(
