Hi, is it possible to build Rasplex from sources and include a local driver source while building it in it? I have Xiaomi Mini USB WiFi dongle, which is not directly supported by the Pi, but has drivers source which can be used to build drivers, but since the Rasplex is based on OpenELEC, I cannot build the driver on it. So I would like to know if it is possible to do so directly while building. Also, please don't suggest Me to buy a new dongle, as they are hard to get where I live.
Please do not double post, there is already a topic for this which you started https://forums.plex.tv/topic/165005-build-on-driver-for-wifi-dongle-on-rasplex/#entry943741
Please check, the thread You quoted although created by Me asks if I can somehow build driver on already available Rasplex OS. Given from the replies, it was clear that it is not possible. This thread is aimed to inquire if I can build Rasplex from sources and modify it while building it, and not the driver only.
Hi, I thanks for the link! Don't why I couldn't find it!
Also, I'm trying to build now, but I get this error. I tried searching it, but no solution seems to come up! I tried searching the file too, but I don't know how to load it manually even if I find it!
Following is the output of build:
./buildman -wrlfi kernel => False ci => False rpversion => wip force => True targetdir => /home/mirhawk/ras/RasPlex/OpenELEC.tv/target outfilename => rasplex-RPi.arm-wip rebuild => True buildtype => release outimagename => rasplex-wip.img devtools => False buildtype_str => LIVEDEBUG="yes" outimagefile => /home/mirhawk/ras/RasPlex/OpenELEC.tv/tmp/rasplex-wip.img linkfast => True version => wip oeversion => devel distroname => rasplex image => True tmpdir => /home/mirhawk/ras/RasPlex/OpenELEC.tv/tmpBuilding rasplex
rm: cannot remove ‘/home/mirhawk/ras/RasPlex/OpenELEC.tv/build.rasplex-RPi.arm-devel-release/.stamps/plexht’: No such file or directory
./scripts/image release
-eConfiguration for rasplex (unofficial)
Buildoptions:
- CPU (ARCH): arm1176jzf-s (arm)
- FLOAT: hard
- FPU: vfp
- SIMD support: no
- Optimizations: size
- LTO (Link Time Optimization) support: yes
- GOLD (Google Linker) Support: yes
- LLVM support:
Graphic configuration:
- XORG support:
- XORG Composite support:
- XORG Xinerama support:
- SDL support: no
- OpenGL (GLX) support (provider): no (no)
- OpenGLES support (provider): yes (bcm2835-driver)
- WindowManager: none
- Xorg Graphic Drivers:
Hardware decoder configuration:
- Broadcom CrystalHD Decoder: no
- XBMC Player driver: bcm2835-driver
- VAAPI Support: no
- VDPAU Support: no
- XVBA Support: no
Input device configuration:
- Remote support: yes
- ATV Remote support: no
- CEC Adapter support: yes
- IRTrans support: no
- XBMC Joystick support: no
Misc. hardware configuration:
- ALSA support: no
- Pulseaudio support:
- Blu-Ray support: yes
- Bluetooth support: yes
- Hardware Sensors support: yes
- LCD drivers: irtrans,imon,imonlcd,mdm166a,MtxOrb,lis,dm140,hd44780,CFontz,SureElec,vlsys_m428
- Include driver: RTL8192CU
- Include driver: RTL8192DU
- Include driver: RTL8188EU
- Include driver: RTL8812AU
- Include firmware: misc-firmware
- Include firmware: wlan-firmware
- Include firmware: dvb-firmware
Network service configuration:
- Avahi (Zeroconf) support: yes
- SAMBA server support: yes
- SFTP server support: yes
- PPTP support: yes
- OpenVPN support: yes
- XBMC Airplay support: yes
- XBMC Airtunes support: yes
- XBMC AFP support: yes
- XBMC NFS support: yes
- XBMC SAMBA client support: yes
- XBMC Webserver support: yes
OS configuration:
- OEM Support: no
- Default Hostname: rasplex
- Default ROOT Password: rasplex
- Bootloader: bcm2835-bootloader
- UDevil support: yes
- Parted support: yes
- UPower support: no
- Installer support: no
Misc. Filesystems:
- Swap Support: yes
- Swapfile default size: 250
- exFAT Support (via Fuse): yes
- NTFS Support (via Fuse): yes
- Install HFS Tools: yes
XBMC configuration:
- XBMC version: plexht
- XBMC nonfree support: yes
- XBMC DVDCSS support: yes
- Include Skin: Confluence
- Default Skin: Confluence
- Include extra fonts: yes
- Include RSXS Screensaver: no
- Include ProjectM Visualization: no
- Include Goom Visualization: no
End Configuration for rasplex
BUILD gcc-final (deprecated packageformat, please convert soon!)
BUILD binutils (deprecated packageformat, please convert soon!)
GET ppl
–2015-06-09 19:32:30-- PPL - BUGSENG
Resolving bugseng.com (bugseng.com)… 160.78.167.1
Connecting to bugseng.com (bugseng.com)|160.78.167.1|:80… connected.
HTTP request sent, awaiting response… 404 Not Found
2015-06-09 19:32:31 ERROR 404: Not Found.
–2015-06-09 19:32:31-- http://sources.rasplex.com/mirror/ppl/ppl-1.1pre10.tar.xz
Resolving sources.rasplex.com (sources.rasplex.com)… 162.243.195.16
Connecting to sources.rasplex.com (sources.rasplex.com)|162.243.195.16|:80… connected.
2015-06-09 19:32:32 ERROR 404: Not Found.
–2015-06-09 19:32:32-- PPL - BUGSENG
2015-06-09 19:32:33 ERROR 404: Not Found.
–2015-06-09 19:32:33-- http://sources.rasplex.com/mirror/ppl/ppl-1.1pre10.tar.xz
2015-06-09 19:32:34 ERROR 404: Not Found.
–2015-06-09 19:32:34-- PPL - BUGSENG
2015-06-09 19:32:35 ERROR 404: Not Found.
–2015-06-09 19:32:35-- http://sources.rasplex.com/mirror/ppl/ppl-1.1pre10.tar.xz
2015-06-09 19:32:36 ERROR 404: Not Found.
–2015-06-09 19:32:36-- PPL - BUGSENG
2015-06-09 19:32:37 ERROR 404: Not Found.
–2015-06-09 19:32:37-- http://sources.rasplex.com/mirror/ppl/ppl-1.1pre10.tar.xz
2015-06-09 19:32:38 ERROR 404: Not Found.
–2015-06-09 19:32:38-- PPL - BUGSENG
2015-06-09 19:32:39 ERROR 404: Not Found.
–2015-06-09 19:32:39-- http://sources.rasplex.com/mirror/ppl/ppl-1.1pre10.tar.xz
–2015-06-09 19:32:39-- PPL - BUGSENG
2015-06-09 19:32:41 ERROR 404: Not Found.
–2015-06-09 19:32:41-- http://sources.rasplex.com/mirror/ppl/ppl-1.1pre10.tar.xz
–2015-06-09 19:32:41-- PPL - BUGSENG
2015-06-09 19:32:42 ERROR 404: Not Found.
–2015-06-09 19:32:42-- http://sources.rasplex.com/mirror/ppl/ppl-1.1pre10.tar.xz
2015-06-09 19:32:43 ERROR 404: Not Found.
–2015-06-09 19:32:43-- PPL - BUGSENG
2015-06-09 19:32:44 ERROR 404: Not Found.
–2015-06-09 19:32:44-- http://sources.rasplex.com/mirror/ppl/ppl-1.1pre10.tar.xz
2015-06-09 19:32:45 ERROR 404: Not Found.
–2015-06-09 19:32:45-- PPL - BUGSENG
2015-06-09 19:32:46 ERROR 404: Not Found.
–2015-06-09 19:32:46-- http://sources.rasplex.com/mirror/ppl/ppl-1.1pre10.tar.xz
–2015-06-09 19:32:46-- PPL - BUGSENG
2015-06-09 19:32:48 ERROR 404: Not Found.
–2015-06-09 19:32:48-- http://sources.rasplex.com/mirror/ppl/ppl-1.1pre10.tar.xz
Cant’t get ppl sources : PPL - BUGSENG
Try later !!
make: *** [release] Error 1
Request processed in 22.00s
Bump?
What's so complicated, your network connection was down it seems...
Actually, I see now your problem. Simply search the file on openelec.tv or somewhere else, and change the download location. Or download into sources/PKG and add file.md5 files.
