Bulk editing features
It would be great to set fields for a group of movies / audio files / etc. at once.
For example there are a lot of different age ratings in place. I would like to filter them and then consolidate all age ratings to one standard. This holds true for many other field types as well.
You can already do that…
You can multi-select the items you want to edit, click Edit – changes will only apply to the fields you set/change across all selected items.
