By Folder Option...
Is there any way to view a movie library with folders in it ‘by folder’ ?
In both the Android and web versions of Plex client, there is an option to view things By Folder…
I can’t seem to find this option on Rasplex…
Any suggestions?
The Android and Web clients are completely unrelated to RasPlex, which is simply an unofficial RPi port of the official PC client “Plex Home Theater” (aka: PHT), which does not have the “by folder” list option. If/when that feature has been implemented for PHT it will of course be ported to the next RasPlex version to follow.
Best regards. dlanor
Any suggestions?
If you had searched you would have found the ‘How to view “by Folder”?’, which somebody else did today, it now visible towards the top of the Rasplex forum, have a read through it.
Regards
