Caldera Headless - Towards General Embedded Streamer Support
Hi, I’ve been really enjoying Caldera so far and wanted to start a thread to discuss moving towards integration with headless streamers. For example, I know there has been some discussion about Wiim integration (which would be awesome). I wanted to also mention RoPieee.
RoPieee is a Raspberry Pi image designed to serve as an audio streamer, that runs multiple audio streaming services in one device and allows for seamless switching between them. For instance, you can Airplay to the device and it will interrupt the ongoing Plexamp stream, or vice versa. Currently there is Plexamp support, which works well, but will be going away now that Plexamp is becoming unmaintained.
There was already some discussion about replacing Plexamp support with Caldera support. It sounds like the minimum needed from the RoPieee dev’s perspective is scripting hooks. Of course open source would be awesome, but seems like that is not in the cards.
Wondering if support for this (or something like it) would ever be considered for Caldera headless. I’m guessing that supporting scripting hooks would open up a wide array of integration possibilities, which would be really cool!
This would be great, I was trying to use RoPieee initially but any 24-bit files would often cause buffering on a pi4 (don’t have this problem with Caldera, thankfully!)
Some more context for use case, to answer the perhaps-inevitable “why not just use Caldera headless by itself?”
Despite my best intentions, I am the only one in my household who uses their Plex library as the primary music library. Therefore I need to have streaming endpoints that support, e.g., Airplay or Spotify Connect. I think this type of use case is pretty common, which is why people buy Wiim streamers.
FWIW, Caldera headless +Plexamp is by far the best experience out of any of these that I have tried.
To be clear, it’s still maintained, but I’m deprecating headless in favor of Caldera.
It is.
Will Plex will continue support plexamp/caldera from server side? Does it has any future or it will become deprecated part of Plex streaming platform?
Plex has never supported Caldera “from the server side” and doesn’t need to.
I support Plexamp and Caldera and have access to the server if there are changes needed to be made.
I’m not sure I follow this. Caldera is brand new and not part of Plex streaming platform.
My concern is that:
  1. Looks like plexamp headless is deprecated. People like ropiee removing it etc. There are not many updates. https://ropieee.org/stable/release/2026/08/16/release-2026.08.html
  2. You created Caldera Headless, however you no longer work for Plex, so If they break compatibility with caldera we all screwed.
Concern is that If I design a system around plexmap/caldera today, will it become obsolete soon and stop working at some point?
my emphasis.
Your concern is unfounded. Only reason why headless Plexamp is deprecated is because Caldera Music is a much better option and I’d rather not waste my time.
