Does ATV HD (2015) work with Caldera? What are the minimum requirements on the hardware and the software side of things for Caldera?
I’m pondering about getting a used ATV and a dummy HDMI dongle just for running Caldera
thanks
thanks
Not exactly sure, the 2015 Apple TV will be powerful enough to handle the visualizer… you should be able to give it a try.
The compatibility page on tvOS simply states it requires tvOS 18.
