I posted this in general discussions but realised I am using the iOS beta so a repost here.
so I started with Camera Upload. Took a day to upload my 5000+ photos. Some seem to have been loaded from iCloud from the plex app and then uploaded to the server.
Next day when I started the upload again it claimed that 2000 are missing (which is inconsistent with the data one day before). One big file (apparently a MOV) is being downloaded, then upload to plex starts and finishes a few milliseconds later. Upload then appears to be finished. Next manual update: Same thing.
Seems to simply “hang” there. I was not able to find anything apparent in the logs. What should I be looking for or supply in order for this to be found?
Here are some logs from the iPhone. However
2017/04/17 16:42:27.657 (156 MB) (526114) I PMKCameraUploadEngine.m:2625 | Something went wrong. Starting process over.
is not really helpful is it?
Regards,
JP
2017/04/17 16:42:27.171 (156 MB) (507845) I PMKCameraUploadEngine.m:1985 | Asset 2015-06-23 21.20.01.MOV is downloading data (100%).
2017/04/17 16:42:27.271 (156 MB) (507845) I PMKAssetController.m:279 | Video export progress: 0.9959989
2017/04/17 16:42:27.416 (156 MB) (525774) I PMKAssetController.m:304 | Video export completed successfully.
2017/04/17 16:42:27.440 (156 MB) (525773) I PMKCameraUploadEngine.m:1766 | Created data transfer task to check partial upload for 2015-06-23 21.20.01.MOV
2017/04/17 16:42:27.440 (156 MB) (525773) I PMKCameraUploadEngine.m:2130 | Ending background task.
2017/04/17 16:42:27.603 (156 MB) (525773) I PMKCameraUploadEngine.m:1277 | Beginning background task.
2017/04/17 16:42:27.604 (156 MB) (525773) I PMKCameraUploadEngine.m:2598 | Found partial upload for asset. Beginning from offset 1770309372
2017/04/17 16:42:27.619 (156 MB) (525774) I PMKFileCopier.m:226 | EOF
2017/04/17 16:42:27.629 (156 MB) (525774) I PMKCameraUploadEngine.m:1771 | Created data transfer task to upload 2015-06-23 21.20.01.MOV
2017/04/17 16:42:27.629 (156 MB) (525774) I PMKCameraUploadEngine.m:2130 | Ending background task.
2017/04/17 16:42:27.656 (156 MB) (526114) I PMKCameraUploadEngine.m:1277 | Beginning background task.
2017/04/17 16:42:27.657 (156 MB) (525774) I PMKCameraUploadEngine.m:1869 | Ending upload.
2017/04/17 16:42:27.658 (157 MB) (525774) I PMKCameraUploadEngine.m:1895 | In the middle of the upload process, attempting to finish up.
2017/04/17 16:42:27.658 (157 MB) (525774) I PMKCameraUploadEngine.m:1899 | No more tasks, all done.
2017/04/17 16:42:27.659 (157 MB) (525774) I PMKCameraUploadEngine.m:1930 | Upload ended.
2017/04/17 16:42:27.659 (157 MB) (525774) I PMKCameraUploadEngine.m:350 | Saving storage info for server jpkcentos
2017/04/17 16:42:27.659 (157 MB) (525774) I PMKCameraUploadEngine.m:2130 | Ending background task.
2017/04/17 16:42:27.780 (156 MB) (525930) I PMKCameraUploadEngine.m:370 | Saved storage info for server jpkcentos
Corresponding entries on the Plex Server:
Apr 17, 2017 16:42:27.552 [0x80c025300] DEBUG - Request: [192.168.202.31:56239 (Allowed Network)] POST /library/metadata?createdAt=1435087201&filename=2015-06-23%2021.20.01.MOV&locationID=20§ionID=9&t
ype=12 (5 live) TLS GZIP Signed-in Token (j.koopmann)
Apr 17, 2017 16:42:27.606 [0x809ee4100] DEBUG - Completed: [192.168.202.31:56239] 308 POST /library/metadata?createdAt=1435087201&filename=2015-06-23%2021.20.01.MOV&locationID=20§ionID=9&type=12 (5 live) TLS GZIP 53ms 231 bytes (pipelined: 1)
Code 308???
Plex Server version: 1.5.3.3580
Plex App: 10224
