when I first configured it 2 months ago it began uploading, but stopped at around 600 of /2000.
since then I have:
experimented with auto library/vs interval updates
recreated the folder /on 2 seperate drives
recreated the share
reset the camera upload
offloaded the app (not deleted) and reinstalled
it never uploads more than 5 now.
I have attached screenshot and logs
I hava a video grab of symptoms and will test with beta app now
Beta app failed too. Same symptoms. Up to date build
Beta app failed too. Same symptoms. Up to date build.
I have the exact same problem like you (stops after 5 uploaded photos) and I have also tried everything. Did this get solved for you or are you still looking for an answer?
No still waiting. I was hoping an admin would translate my logs…
It appears possiblly removing the app (completely) and reinstalling may fix.
I’m dubious though as beta app does same thing.
https://forums.plex.tv/discussion/comment/1590293#Comment_1590293
Did you reinstall the app?
I have the exact same problem like you (stops after 5 uploaded photos) and I have also tried everything. Did this get solved for you or are you still looking for an answer?No still waiting. I was hoping an admin would translate my logs…
I’m dubious though as beta app does same thing.Did you reinstall the app?
Ok I reinstalled the app.
Removed the library
created a new folder
Created a new library.
Same issue.
Had to re sync
Removed the library
Same issue.Had to re sync
Is this still happening ?
I can see errors in the January 8th log which look like some timing issue - a temporary file for upload not accessible.
What is the version of the Plex for iOS app you are using ?
And what version of Plex Media Server ?
If it is still happening please get me logs with the current versions (and keeping verbose logging as well debug on the server - as verbose is important for camera upload issues)
The log you provided was good - capturing the problem after few uploads and after a server restart. Before submitting it as an issue to the development team, I need it to be tried on latest beta version 1.12.0.4829
So please download it from https://plex.tv/downloads and install it and then reproduce the problem and get me new logs
I found that if I modified a image that was stuck in the camera roll it would upload. These images are items migrated from a previous phone. I’m thinking it’s more of a permission issue.
All
Of my stuff was up to date and has been for the many months this has been happening.
I’m running server Version 1.11.3.4803.
EDIT: I have updated to version 1.12.0.4829
Exact issue remains.
 the images themselves however did exist on another phone. However I think that’s a mute point as found that that all the images in the Plex camera roll read as a size 0.0kb
Wanted to see the subdirectories lists
So please these as well
/var/folders/vz/q3503kbj12q4l7npz1q4bf400000gn/T/Plex/Upload/2639994/82DA31AF-1242-486E-8C14-6FBBED1CE508/17
/var/folders/vz/q3503kbj12q4l7npz1q4bf400000gn/T/Plex/Upload/2639994/80FDD80D-D610-49C1-B3DC-85518A8102C4/17
I am a bit confused about the owner group names
So we have owner as ladmin and owner group as staff for one set of folders but owner as ladmin and owner group as wheel - how come?
Extract:
andycarver:~ ladmin$ cd /var/folders/vz/q3503kbj12q4l7npz1q4bf400000gn/T/Plex/Upload/2639994/
andycarver:2639994 ladmin$ ls -alh
total 24
drwxr-xr-x 6 ladmin staff 204B Mar 3 07:32 .
drwxr-xr-x 4 ladmin staff 136B Mar 3 07:32 ..
-rw-r--r--@ 1 ladmin staff 8.0K Mar 3 07:33 .DS_Store
drwxr-xr-x 4 ladmin staff 136B Mar 3 07:33 80FDD80D-D610-49C1-B3DC-85518A8102C4
and
andycarver:2639994 ladmin$ ls -alh "/Volumes/Data/Camera Roll Upload"
total 18008
drwxr-xr-x 12 ladmin wheel 408B Mar 2 21:51 .
drwxrwxr-x 11 root wheel 442B Mar 2 19:52 ..
and you mentioned that the images were zero length and your screenshot is of 2014-08-03 16:08 but there is no such file in your list directory
total 18008
The last 2 were actually successfully uploaded according to the logs and should not show as zero length.
Your Photos library has two paths
/Users/ladmin/Pictures/Photos Library.photoslibrary/Masters
may be the zero length files were not in the camera upload path but the 2nd path
That size was reported in the iOS app only.
I can’t explain how the permissions appear like that. Is it not expected? The PMS app runs inside the user (ladmin). Does PMS require root user permissions?
Should I delete the contents of /var/folders/vz/q3503kbj12q4l7npz1q4bf400000gn/T/Plex/Upload/
and the share in /Volumes/Data/
I can’t explain how the permissions appear like that. Is it not expected? The PMS app runs inside the user (ladmin). Does PMS require root user permissions?Should I delete the contents of /var/folders/vz/q3503kbj12q4l7npz1q4bf400000gn/T/Plex/Upload/
Deleting /var/folders/vz/q3503kbj12q4l7npz1q4bf400000gn/T/Plex/Upload/2639994/82DA31AF-1242-486E-8C14-6FBBED1CE508 may help for any stuck uploads
but I am still waiting for you to get me the list directory output for each of these
ls -alh /var/folders/vz/q3503kbj12q4l7npz1q4bf400000gn/T/Plex/Upload/2639994/82DA31AF-1242-486E-8C14-6FBBED1CE508/17
ls -alh /var/folders/vz/q3503kbj12q4l7npz1q4bf400000gn/T/Plex/Upload/2639994/80FDD80D-D610-49C1-B3DC-85518A8102C4/17
With regards to your library setup, did you want to combine camera uploads and other photos into one library? At the moment your photos library has these paths defined
Is there any solution for this issue?
I have the same problem - camera upload stops after random number of uploaded photos.
Android version: 9
Plex client version: 7.19.2.117899 (5a12aa06)
Plex server version: 1.16.3.1402
The solution for me was to keep the charger attached all the time during upload.
Never stopped upload since.
