Server Version#:
I just created a backup (alternative server) in case the first one goes down.
Now I would like to see my main server first in the web interface.
Is there a way to move the newly created server down the list?
I tried changing the name figuring “Alt Server” to “Z alt server” thinking it might be an alfabetical issue. did not help. Is there another way?
No, the items under More should be ordered alphabetically. If you re-named the server and it’s still showing in the original order – have you already tried reloading Plex Web since you renamed it?
