2 questions
have 3 pcs with plex, if one is off I noticed that keeps iintermittently timimg.
Is this normal and if so can how often be controlled ?
Is there a way to control which server is listed first ?
2 questions
It is normal and no, it cannot be customized.
Which client and at which menu or screen?
If you mean the web app and its left side bar, after pressing ‘MORE’: alphabetically sorting of the “friendly name” (set that under Settings - Server - General)
If you mean the very first screen of any app, you can customize that.
First, reset it and then decide on a default server:
https://support.plex.tv/articles/customizing-the-mobile-apps-2#reset
https://support.plex.tv/articles/customizing-the-apps#reset
https://support.plex.tv/articles/customizing-plex-web#resethome
After doing that, you can customize which library of which server is shown by default, in which order.
