Reorder servers (not libraries)
Apologies that this is probably a very straightforward answer but with the new UI that’s being rolled out I can’t seem to control the order of my Plex Servers. I’m not talking about the order of individual libraries, but specifically the order of servers. i.e. how they are listed in the drop-down of the settings section or how they are ordered in the “More” section of the new left-hand navigation.
Thanks in advance!
They appear to be ordered strictly alphabetical.
First your own servers,
then servers shared with you
and online media sources at the bottom.
So the only thing you can do is ordering your own servers by renaming them.
Thanks OttoKerner but I did try renaming one of my servers and it didn’t change the order.
Anything else I need to do after changing it or is there some other ordering being used?
Perry
They are reordered. You just need to refresh the web app in the browser.
With other clients, it may take a while until the change trickles down, but it will eventually.
