Hello,
I’m interested in two plugins for my Plex server hosted on my Synology NAS, namely
Tautulli and Sub-Zero
I can however not see that I actually can install them on my server?
Is it at all possible?
Hello,
Thank you trumpy81.
Reading through this list I got the impression these where nice plugins to have in 2021.
I’ll see if I can install Tautulli using Docker.
For the subtitles I was hoping this plugin could change the appearance of them so that they are not so bright on my OLED TV. As they are now they are so bright that they are distracting… I was hoping I could make them greyer.
Do you have a suggestion on how to fix this?
Do you know where I can find instructions on how to install Tautulli on my NAS using Docker?
Well that is a useless comment.
I have “googled it” but all I’ve fount talk about SSH into the NAS, scripting and my personal favourite: “Create and run the container (substitute your <values> ) with the following command”
I have no idea what they are talking about.
If Tautulli is just a software that is to be installed on my NAS, all these instructions I’ve found do not seem to be useful for anything. I do not see that it should be that complicated.
So thanks for nothing flow. You contributed with nothing.
And there you allowed yourself to say that…
