Can I use Plex on a Chromebook?
If so which server should I download
If not then why does Plex have a Chrome Extension?
I haven’t used it extensively, but you can use the web player on a Chromebook.
If you mean can you run a Plex server on a Chromebook, the answer is no. The Chrome Extension is only to play your content that you run from a separate server, this can be a Windows desktop PC, Linux machine, Mac, NAS or the upcoming Plex cloud, to name a few options available to you.
