The new series The Endgame is setting Intro Skip to skip over part of the episode presumable because it uses identical music.
Is there a way to disable intro skip for a single series or can it only be done for the entire library?
From what I remember, you cannot enable/disable skip intro for individual shows.
The following applies to a Linux server, your mileage under Windows may vary.
If you look under the Live TV & DVR/Scheduled Recordings/Recording priority, your scheduled programs/series appear down the right side. Locate your series, pull up it’s properties, and under advanced, you can play with the settings for detect commercials. This may be related to the detect intro function as well.
Nope.
