Can not change skin
Hi! I have installed Rasplex 1.8 on my Sandisk 16GB USB pendrive (I have enabled USB Boot on my Raspberrypi 3), but I can not change skin, either Aeon either Black. When manually copied downloaded skins into proper directory, there are on the menu list, however nothing happens when I accept skin change. Can anyone help?
You must install them manually until the problem its fixed
I did. However when I choose and accept new skin nothing happens. It just hangs. Raspberrypi green front LED is constant blinking (I do not know if it matters).
