Just to let everyone know that @DeadEyeFlint and @MagnumDoomguy recently joined the Rasplex/OpenPHT team so that their awesome skins are always updated to include the latest new features and fixes.
That’s awesome news! And…just because I’m feeling lazy…any chance you can just include these as a selectable skin with the default install of Rasplex (…since these guys are officially part of the team)?
Aeon Nox by MagnumDoomguy is really the best skin I have even seen. Really love the way he is implementing all the features. Running great on rpi2, Keep up the good work!
Yes you can, install the skins and from Preferences, select the skin you want to use, when you’ve tried one, just repeat. Note that loading a skin after selecting it will take a little time.
I’ve taken the SD card out of the raspberry pi and looked into it on my mac and there is no folder named as you have below?
Any help would be appreciated.
JT.
ok i’m using cyberduck to access the pi 3 but there is no .plexht folder. Do I need to create the folder for it?
Using the SSH SFTP option logging in as root/rasplex
@chenks said:
that’s because you would have to mount the card using a third party tool to get access to the file system.
OSX does not natively support it.
