Note down exact time of start of capture - you could call time command in the command line immediately before calling curl
and whilst the capture is running, then do the test for recording from 33.1
and when it fails, stop the curl capture and let me have all the diagnostics
I’ve seen the same thing when trying to watch 33.1 live with the Android app (but not with the Plex application in Windows). Asks if I’d like to watch from the start 504 mins ago, where it’s not being recorded at the time. I’m starting to suspect there is something in the ION transport stream data that Plex doesn’t like.
That appears to be the problem area - all to do with time and what time the segments represent - I am not sure where in the .ts file that information would be but it appears the problem area.
@sa2000 Has there been any progress on this? I need to cut expenses with the COVID-19 economic downturn (I’m being furloughed one week a month), and when this is fixed I can stop paying for Channels DVR.
I suspect you are correct. I tried another recording, and it quit after a few minutes, partial recording, with the reason that the recording was canceled.
@sa2000 I’m hoping this gets resolved eventually, based on what I’ve seen elsewhere in the forum the Plex DVR cannot record shows on ION Television anywhere in the US.
