DVR records for a few seconds then stops
Using a WinTV-quadHD tuner which has worked well for years. Recently, DVR only records a few seconds the stops. Noticed live TV also plays for a few seconds, then buffers for several seconds, but then continues just fine. Any help would be appreciated. I am such a fan of Plex and sing its praises every chance I get.
I see a similar issue with my USB TV tuner EyeTV Hybrid
Without additional information I would suggest you check the signal strength at your tuner. Debug level server logs that cover the period of failed tune attempts would be very helpful in identifying the cause.
where do I find the logs in my file system (using ubuntu)? or are they only available within the app? there I seem to see nothing…
however, meanwhile I can report that I can see all kinds of broken recordings:
  • stop after a few seconds to stop after more than one hour but before end of the movie
  • size zero for recorded files (so somehow it started but did not record anything
  • recording starts only in the middle of the movie…
Probably easiest to download them via the web app ( https://app.plex.tv/web)
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
Thanks, I found them :slight_smile:
however, I don’t understand why there are so many entries (every 3 sec) in the Tuner Service Log like this:
Apr 17, 2023 16:58:55.911 [0x7f9caeae4b38] INFO - [I] web_service_t::process_device_status
Apr 17, 2023 16:58:55.911 [0x7f9caeae4b38] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Apr 17, 2023 16:58:55.911 [0x7f9caeae4b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Apr 17, 2023 16:58:55.912 [0x7f9caeae4b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Apr 17, 2023 16:58:58.967 [0x7f9caededb38] INFO - [I] web_service_t::process_device_status
Apr 17, 2023 16:58:58.967 [0x7f9caededb38] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Apr 17, 2023 16:58:58.967 [0x7f9caededb38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Apr 17, 2023 16:58:58.968 [0x7f9caededb38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
in addition I see a huge amount of WARN and ERROR in the server log like this, which does not look healthy to me…
Apr 17, 2023 11:02:58.743 [0x7f0eef015b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F6070c2c945c6ab002d9f370b
Apr 17, 2023 11:02:58.743 [0x7f0eef015b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 11:02:58.752 [0x7f0eef218b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 11:02:58.752 [0x7f0eef218b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F5fc693631a65df002dd2add1
Apr 17, 2023 11:02:58.752 [0x7f0eef218b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 11:02:58.779 [0x7f0eeec0fb38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 11:02:58.779 [0x7f0eeec0fb38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F5fc692a3a7560c002d58618a
Apr 17, 2023 11:02:58.779 [0x7f0eeec0fb38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 11:02:58.793 [0x7f0eef218b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 11:02:58.793 [0x7f0eef218b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F5ff350931eb136002dabe17d
Apr 17, 2023 11:02:58.793 [0x7f0eef218b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 11:02:58.793 [0x7f0eeec0fb38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 11:02:58.793 [0x7f0eeec0fb38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F5fe95176734f0a002e4577ac
Apr 17, 2023 11:02:58.793 [0x7f0eeec0fb38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 11:02:58.795 [0x7f0eeee12b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 11:02:58.795 [0x7f0eeee12b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F5ff3509c577cf7002d0a4fcc
Apr 17, 2023 11:02:58.795 [0x7f0eeee12b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 11:03:47.621 [0x7f0eefc27b38] ERROR - [CreditsDetectionManager] BufferingLineReader: failed to read line (error: -1)
Apr 17, 2023 11:12:18.123 [0x7f0eef61eb38] ERROR - getaddrinfo(192-168-246-131.abcdefghijklmnopqrstuvwxyz012345.plex.direct) failed: -2
Apr 17, 2023 11:12:21.744 [0x7f0ef27dcb38] WARN - NAT: PMP, got an error: Version not supported.
Apr 17, 2023 11:16:08.147 [0x7f0eefc49b38] WARN - [Req#9cb7] Invalid library section ID 1 passed.
Apr 17, 2023 11:16:46.654 [0x7f0ef0e6fb38] ERROR - [Req#9cd7] Unknown metadata type: mixed
Apr 17, 2023 11:21:13.179 [0x7f0ef2fe8b38] INFO - Library section 2 (Andere Videos) will be updated because of a change in "/home/christoph/Videos/mediathek11852002493171893749tmp"
Apr 17, 2023 11:21:41.780 [0x7f0ef29dfb38] ERROR - [Req#9e32] Unknown metadata type: folder
Apr 17, 2023 11:21:41.849 [0x7f0ef29dfb38] ERROR - [Req#9e31] Unknown metadata type: folder
Apr 17, 2023 11:24:35.106 [0x7f0eef61eb38] WARN - [Req#9e7d] WebSocket: Ignoring message since we're closing the connection
Apr 17, 2023 11:24:51.193 [0x7f0ef91f9b38] WARN - JobManager: Could not find job for handle 105501
Apr 17, 2023 11:24:52.327 [0x7f0ef91f9b38] WARN - JobManager: Could not find job for handle 105534
Apr 17, 2023 11:28:06.036 [0x7f0eef821b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 11:28:06.036 [0x7f0eef821b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F614ab2ad70e077d5925d3a40
Apr 17, 2023 11:28:06.036 [0x7f0eef821b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 11:28:06.039 [0x7f0eef41bb38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 11:28:06.039 [0x7f0eef41bb38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F5fc68f8b843f5c002dc52ebd
Apr 17, 2023 11:28:06.039 [0x7f0eef41bb38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 11:28:06.047 [0x7f0eef821b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 11:28:06.047 [0x7f0eef821b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F5fc693631a65df002dd2add1
Apr 17, 2023 11:28:06.047 [0x7f0eef821b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 11:28:06.047 [0x7f0eefa24b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 11:28:06.047 [0x7f0eefa24b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F6070c2c945c6ab002d9f370b
Apr 17, 2023 11:28:06.047 [0x7f0eefa24b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 11:28:06.063 [0x7f0eef41bb38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 11:28:06.063 [0x7f0eef41bb38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F5fc692a3a7560c002d58618a
Apr 17, 2023 11:28:06.063 [0x7f0eef41bb38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 11:58:12.838 [0x7f0ef91f9b38] WARN - JobManager: Could not find job for handle 109886
Apr 17, 2023 11:58:13.719 [0x7f0ef91f9b38] WARN - JobManager: Could not find job for handle 109929
Apr 17, 2023 12:12:18.266 [0x7f0ef34fdb38] ERROR - getaddrinfo(192-168-246-131.abcdefghijklmnopqrstuvwxyz012345.plex.direct) failed: -2
Apr 17, 2023 12:12:21.879 [0x7f0ef34fdb38] WARN - NAT: PMP, got an error: Version not supported.
Apr 17, 2023 13:12:18.380 [0x7f0eef61eb38] ERROR - getaddrinfo(192-168-246-131.abcdefghijklmnopqrstuvwxyz012345.plex.direct) failed: -2
Apr 17, 2023 13:12:22.049 [0x7f0ef27dcb38] WARN - NAT: PMP, got an error: Version not supported.
Apr 17, 2023 14:12:18.633 [0x7f0ef27dcb38] ERROR - getaddrinfo(192-168-246-131.abcdefghijklmnopqrstuvwxyz012345.plex.direct) failed: -2
Apr 17, 2023 14:12:22.249 [0x7f0ef34fdb38] WARN - NAT: PMP, got an error: Version not supported.
Apr 17, 2023 15:12:18.746 [0x7f0ef27dcb38] ERROR - getaddrinfo(192-168-246-131.abcdefghijklmnopqrstuvwxyz012345.plex.direct) failed: -2
Apr 17, 2023 15:12:22.400 [0x7f0ef29dfb38] WARN - NAT: PMP, got an error: Version not supported.
Apr 17, 2023 16:12:18.837 [0x7f0ef29dfb38] ERROR - getaddrinfo(192-168-246-131.abcdefghijklmnopqrstuvwxyz012345.plex.direct) failed: -2
Apr 17, 2023 16:12:22.403 [0x7f0ef29dfb38] WARN - NAT: PMP, got an error: Version not supported.
Apr 17, 2023 16:27:26.532 [0x7f0ef0839b38] INFO - [Req#a53f] AutoUpdate: no updates available
Apr 17, 2023 16:27:31.643 [0x7f0ef0636b38] INFO - [Req#a598] AutoUpdate: no updates available
Apr 17, 2023 16:27:34.032 [0x7f0ef27dcb38] WARN - [Req#a5a6] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Apr 17, 2023 16:27:34.032 [0x7f0ef27dcb38] WARN - [Req#a5a6] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Apr 17, 2023 16:27:34.036 [0x7f0ef27dcb38] WARN - [Req#a5a6] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Apr 17, 2023 16:27:34.037 [0x7f0ef27dcb38] WARN - [Req#a5a6] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Apr 17, 2023 16:27:34.039 [0x7f0ef27dcb38] WARN - [Req#a5a6] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Apr 17, 2023 16:27:34.039 [0x7f0ef27dcb38] WARN - [Req#a5a6] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Apr 17, 2023 16:27:34.044 [0x7f0ef27dcb38] WARN - [Req#a5a6] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Apr 17, 2023 16:27:34.044 [0x7f0ef27dcb38] WARN - [Req#a5a6] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Apr 17, 2023 16:38:17.783 [0x7f0ef29b1b38] ERROR - [Req#aae0] Unknown metadata type: folder
Apr 17, 2023 16:38:17.796 [0x7f0ef0a3cb38] ERROR - [Req#aade] Unknown metadata type: folder
Apr 17, 2023 16:42:00.837 [0x7f0eef94ab38] ERROR - [Req#aebe/Grabber/5882164c050da954be381d80482e7463247a2e1b] Unable to find title for item of type 5
Apr 17, 2023 16:42:02.690 [0x7f0ef0839b38] ERROR - [Req#af10/Transcode/49a855da-b02f-4b6b-838b-efae022b7edf/1b74cbe9-d177-46ee-bcc9-e3ab546703aa] [mpeg2video @ 0x7f02688fa640] Invalid frame dimensions 0x0.
Apr 17, 2023 16:42:02.691 [0x7f0ef0a3cb38] ERROR - [Req#af11/Transcode/49a855da-b02f-4b6b-838b-efae022b7edf/1b74cbe9-d177-46ee-bcc9-e3ab546703aa] [mpeg2video @ 0x7f02688fa640] Invalid frame dimensions 0x0.
Apr 17, 2023 16:42:02.692 [0x7f0ef1072b38] ERROR - [Req#af12/Transcode/49a855da-b02f-4b6b-838b-efae022b7edf/1b74cbe9-d177-46ee-bcc9-e3ab546703aa] [mpeg2video @ 0x7f02688fa640] Invalid frame dimensions 0x0.
Apr 17, 2023 16:42:02.698 [0x7f0ef0839b38] ERROR - [Req#af13/Transcode/49a855da-b02f-4b6b-838b-efae022b7edf/1b74cbe9-d177-46ee-bcc9-e3ab546703aa] [mpeg2video @ 0x7f02688fa640] Invalid frame dimensions 0x0.
Apr 17, 2023 16:42:02.701 [0x7f0ef0a3cb38] ERROR - [Req#af14/Transcode/49a855da-b02f-4b6b-838b-efae022b7edf/1b74cbe9-d177-46ee-bcc9-e3ab546703aa] [mpeg2video @ 0x7f02688fa640] Invalid frame dimensions 0x0.
Apr 17, 2023 16:42:02.702 [0x7f0ef1072b38] ERROR - [Req#af15/Transcode/49a855da-b02f-4b6b-838b-efae022b7edf/1b74cbe9-d177-46ee-bcc9-e3ab546703aa] [mpeg2video @ 0x7f02688fa640] Invalid frame dimensions 0x0.
Apr 17, 2023 16:42:02.703 [0x7f0ef0839b38] ERROR - [Req#af16/Transcode/49a855da-b02f-4b6b-838b-efae022b7edf/1b74cbe9-d177-46ee-bcc9-e3ab546703aa] [mpeg2video @ 0x7f02688fa640] Invalid frame dimensions 0x0.
Apr 17, 2023 16:42:02.704 [0x7f0ef0a3cb38] ERROR - [Req#af17/Transcode/49a855da-b02f-4b6b-838b-efae022b7edf/1b74cbe9-d177-46ee-bcc9-e3ab546703aa] [mpeg2video @ 0x7f02688fa640] Invalid frame dimensions 0x0.
Apr 17, 2023 16:42:02.705 [0x7f0ef1072b38] ERROR - [Req#af18/Transcode/49a855da-b02f-4b6b-838b-efae022b7edf/1b74cbe9-d177-46ee-bcc9-e3ab546703aa] [mpeg2video @ 0x7f02688fa640] Invalid frame dimensions 0x0.
Apr 17, 2023 16:42:02.766 [0x7f0ef0839b38] ERROR - [Req#af19/Transcode/49a855da-b02f-4b6b-838b-efae022b7edf/1b74cbe9-d177-46ee-bcc9-e3ab546703aa] [mpeg2video @ 0x7f02688fa640] Invalid frame dimensions 0x0.
Apr 17, 2023 16:42:03.285 [0x7f0eef94ab38] ERROR - [Req#aebe/Grabber/5882164c050da954be381d80482e7463247a2e1b] Unable to find title for item of type 5
Apr 17, 2023 16:42:03.286 [0x7f0eef94ab38] ERROR - [Req#aebe/Grabber/5882164c050da954be381d80482e7463247a2e1b] Unable to find title for item of type 5
No glaring errors in those excerpts and most can be ignored as diagnostic messages. Without the full set of logs it is tough to form context of what is happening from so little.
USB tuners tend to be problematic since they can change location after a reboot or dropping offline (powersave).
In the ā€˜Plex Media Server.log’ file, the better words to look for would be corrupt, failed, access denied and http 400/500 errors. You can try to start a live stream and watch for Signal messages to find out how good the signal is.
thanks for the hints, I’ll watch the logs and post them on the next recording fail.
regarding the USB devices: I’m aware of these issues, but Apps like Kaffeine do not show recording issues on my Ubuntu system
BTW: I also tried to go through TVHeadend with Antennas Proxy, but the results were worse than direct access to the USB Devices by DVB-API of Linux…
here is a complete log of two attempts to start a live TV stream, which failed, while the third attempt worked.
I assume this is similar to what happens if I get a recording file of zero bytes…
Apr 17, 2023 20:31:18.095 [0x7f0eeed38b38] ERROR - [Req#35ab3] Unknown metadata type: mixed
Apr 17, 2023 20:34:41.988 [0x7f0eeeb35b38] ERROR - [Req#36556] Unknown metadata type: mixed
Apr 17, 2023 20:35:23.359 [0x7f0eeeb35b38] ERROR - [Req#367c6] Unknown metadata type: mixed
Apr 17, 2023 20:35:53.099 [0x7f0eeeb35b38] ERROR - [Req#36935] Unknown metadata type: mixed
Apr 17, 2023 20:36:47.711 [0x7f0eeed38b38] ERROR - [Req#36ce7] Unknown metadata type: mixed
Apr 17, 2023 20:38:08.123 [0x7f0eeeb35b38] ERROR - [Req#37158] Unknown metadata type: mixed
Apr 17, 2023 20:38:39.834 [0x7f0eeeb35b38] ERROR - [Req#372fc] Unknown metadata type: mixed
Apr 17, 2023 20:41:49.509 [0x7f0eeeb35b38] ERROR - [Req#37d94] Unknown metadata type: mixed
Apr 17, 2023 20:42:25.449 [0x7f0eeed38b38] ERROR - [Req#37fff] Unknown metadata type: mixed
Apr 17, 2023 20:42:25.450 [0x7f0eeed38b38] ERROR - [Req#37fff] Unknown metadata type: mixed
Apr 17, 2023 20:44:01.031 [0x7f0eeed38b38] ERROR - [Req#38525] Unknown metadata type: mixed
Apr 17, 2023 20:45:18.542 [0x7f0eeeb35b38] ERROR - [Req#3894e] Unknown metadata type: mixed
Apr 17, 2023 20:46:07.762 [0x7f0eeed38b38] ERROR - [Req#38c0d] Unknown metadata type: mixed
Apr 17, 2023 20:47:31.523 [0x7f0eeeb35b38] ERROR - [Req#390da] Unknown metadata type: mixed
Apr 17, 2023 20:47:31.524 [0x7f0eeeb35b38] ERROR - [Req#390da] Unknown metadata type: mixed
Apr 17, 2023 20:48:05.414 [0x7f0eeed38b38] ERROR - [Req#39398] Unknown metadata type: mixed
Apr 17, 2023 20:49:56.038 [0x7f0eee554b38] ERROR - [Req#39a25/Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da44-ur0f3rawijlxsx900r96vbkw] Unable to find title for item of type 5
Apr 17, 2023 20:49:57.566 [0x7f0eef13eb38] ERROR - [Req#39a80/Transcode/e48a9afe-dd31-4736-bd80-79558b3f12ba/d5c702f0-0bb9-43a5-b3a8-cd6033e6d670] [mpeg2video @ 0x7fc757102140] Invalid frame dimensions 0x0.
Apr 17, 2023 20:49:57.569 [0x7f0eeef3bb38] ERROR - [Req#39a82/Transcode/e48a9afe-dd31-4736-bd80-79558b3f12ba/d5c702f0-0bb9-43a5-b3a8-cd6033e6d670] [mpeg2video @ 0x7fc757102140] Invalid frame dimensions 0x0.
Apr 17, 2023 20:49:57.570 [0x7f0eef747b38] ERROR - [Req#39a83/Transcode/e48a9afe-dd31-4736-bd80-79558b3f12ba/d5c702f0-0bb9-43a5-b3a8-cd6033e6d670] [mpeg2video @ 0x7fc757102140] Invalid frame dimensions 0x0.
Apr 17, 2023 20:49:57.572 [0x7f0ef1072b38] ERROR - [Req#39a84/Transcode/e48a9afe-dd31-4736-bd80-79558b3f12ba/d5c702f0-0bb9-43a5-b3a8-cd6033e6d670] [mpeg2video @ 0x7fc757102140] Invalid frame dimensions 0x0.
Apr 17, 2023 20:49:57.574 [0x7f0ef002db38] ERROR - [Req#39a85/Transcode/e48a9afe-dd31-4736-bd80-79558b3f12ba/d5c702f0-0bb9-43a5-b3a8-cd6033e6d670] [mpeg2video @ 0x7fc757102140] Invalid frame dimensions 0x0.
Apr 17, 2023 20:49:57.575 [0x7f0eee344b38] ERROR - [Req#39a86/Transcode/e48a9afe-dd31-4736-bd80-79558b3f12ba/d5c702f0-0bb9-43a5-b3a8-cd6033e6d670] [mpeg2video @ 0x7fc757102140] Invalid frame dimensions 0x0.
Apr 17, 2023 20:49:57.589 [0x7f0eef13eb38] ERROR - [Req#39a87/Transcode/e48a9afe-dd31-4736-bd80-79558b3f12ba/d5c702f0-0bb9-43a5-b3a8-cd6033e6d670] [mpeg2video @ 0x7fc757102140] Invalid frame dimensions 0x0.
Apr 17, 2023 20:49:57.637 [0x7f0eeef3bb38] ERROR - [Req#39a88/Transcode/e48a9afe-dd31-4736-bd80-79558b3f12ba/d5c702f0-0bb9-43a5-b3a8-cd6033e6d670] [mpeg2video @ 0x7fc757102140] Invalid frame dimensions 0x0.
Apr 17, 2023 20:49:57.645 [0x7f0eef747b38] ERROR - [Req#39a89/Transcode/e48a9afe-dd31-4736-bd80-79558b3f12ba/d5c702f0-0bb9-43a5-b3a8-cd6033e6d670] [mpeg2video @ 0x7fc757102140] Invalid frame dimensions 0x0.
Apr 17, 2023 20:49:57.693 [0x7f0eef13eb38] ERROR - [Req#39a8a/Transcode/e48a9afe-dd31-4736-bd80-79558b3f12ba/d5c702f0-0bb9-43a5-b3a8-cd6033e6d670] [mpeg2video @ 0x7fc757102140] Invalid frame dimensions 0x0.
Apr 17, 2023 20:49:57.717 [0x7f0ef1072b38] ERROR - [Req#39a92/Transcode/e48a9afe-dd31-4736-bd80-79558b3f12ba/d5c702f0-0bb9-43a5-b3a8-cd6033e6d670] [mpeg2video @ 0x7fc757102140] Invalid frame dimensions 0x0.
Apr 17, 2023 20:49:57.773 [0x7f0ef002db38] ERROR - [Req#39a95/Transcode/e48a9afe-dd31-4736-bd80-79558b3f12ba/d5c702f0-0bb9-43a5-b3a8-cd6033e6d670] [mpeg2video @ 0x7fc757102140] Invalid frame dimensions 0x0.
Apr 17, 2023 20:49:57.829 [0x7f0eee344b38] ERROR - [Req#39a96/Transcode/e48a9afe-dd31-4736-bd80-79558b3f12ba/d5c702f0-0bb9-43a5-b3a8-cd6033e6d670] [mpeg2video @ 0x7fc757102140] Invalid frame dimensions 0x0.
Apr 17, 2023 20:49:58.379 [0x7f0eee554b38] ERROR - [Req#39a25/Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da44-ur0f3rawijlxsx900r96vbkw] Unknown metadata type:
Apr 17, 2023 20:50:03.558 [0x7f0ef1072b38] ERROR - [Req#39b68/Transcode/5kfnc5qf3tnow8x72mln7eht/3cee231c-471a-4e64-853b-efa66fd2f29e] [segment @ 0x7fe3994ba040] sample rate not set
Apr 17, 2023 20:50:03.559 [0x7f0eebcb2b38] ERROR - [Req#39b6c/Transcode/5kfnc5qf3tnow8x72mln7eht/3cee231c-471a-4e64-853b-efa66fd2f29e] Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
Apr 17, 2023 20:50:03.561 [0x7f0eef13eb38] ERROR - [Req#39b6d/Transcode/5kfnc5qf3tnow8x72mln7eht/3cee231c-471a-4e64-853b-efa66fd2f29e] Error initializing output stream 0:1 --
Apr 17, 2023 20:50:03.563 [0x7f0eee344b38] ERROR - [Req#39b6f/Transcode/5kfnc5qf3tnow8x72mln7eht/3cee231c-471a-4e64-853b-efa66fd2f29e]
Apr 17, 2023 20:50:03.659 [0x7f0ef8df3b38] ERROR - [TranscodeOutputStream] Session appears to have died from under us
Apr 17, 2023 20:51:39.272 [0x7f0eee554b38] ERROR - [Req#3a051/Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da44-ur0f3rawijlxsx900r96vbkw] Unable to find title for item of type 5
Apr 17, 2023 20:51:40.850 [0x7f0eee344b38] ERROR - [Req#3a092/Transcode/1ab5416c-770b-42ca-9220-69f431ed1c2c/1f0e5b55-55ae-4333-bdba-86081b42064d] [mpeg2video @ 0x7fa872316680] Invalid frame dimensions 0x0.
Apr 17, 2023 20:51:40.853 [0x7f0eef747b38] ERROR - [Req#3a093/Transcode/1ab5416c-770b-42ca-9220-69f431ed1c2c/1f0e5b55-55ae-4333-bdba-86081b42064d] [mpeg2video @ 0x7fa872316680] Invalid frame dimensions 0x0.
Apr 17, 2023 20:51:47.773 [0x7f0eee554b38] ERROR - [Req#3a051/Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da44-ur0f3rawijlxsx900r96vbkw] Unknown metadata type:
Apr 17, 2023 20:51:50.430 [0x7f0eee344b38] ERROR - [Req#3a16a/Transcode/v3k2uad17e8j86wkb8oftuyf/93a1e4b4-5008-4d44-a679-a2dd2f50101a] [segment @ 0x7fc4c9de1040] dimensions not set
Apr 17, 2023 20:51:50.431 [0x7f0eef13eb38] ERROR - [Req#3a16c/Transcode/v3k2uad17e8j86wkb8oftuyf/93a1e4b4-5008-4d44-a679-a2dd2f50101a] Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
Apr 17, 2023 20:51:50.432 [0x7f0eeef3bb38] ERROR - [Req#3a16d/Transcode/v3k2uad17e8j86wkb8oftuyf/93a1e4b4-5008-4d44-a679-a2dd2f50101a] Error initializing output stream 0:1 --
Apr 17, 2023 20:51:50.433 [0x7f0eebcb2b38] ERROR - [Req#3a16e/Transcode/v3k2uad17e8j86wkb8oftuyf/93a1e4b4-5008-4d44-a679-a2dd2f50101a]
Apr 17, 2023 20:51:50.453 [0x7f0eefdffb38] WARN - [Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da44-ur0f3rawijlxsx900r96vbkw] SLOW QUERY: It took 330.000000 ms to retrieve 43 items.
Apr 17, 2023 20:51:50.530 [0x7f0ef8ff6b38] ERROR - [TranscodeOutputStream] Session appears to have died from under us
Apr 17, 2023 20:52:19.854 [0x7f0eef341b38] ERROR - [Req#3a2fa/Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da44-ur0f3rawijlxsx900r96vbkw] Unable to find title for item of type 5
Apr 17, 2023 20:52:21.509 [0x7f0eee344b38] ERROR - [Req#3a350/Transcode/4d3af795-8bfc-4079-ae72-00d116742299/4d7e7d20-9fe6-4e55-80ae-166d5c930733] [mpeg2video @ 0x7f286026d640] Invalid frame dimensions 0x0.
Apr 17, 2023 20:52:21.511 [0x7f0eeef3bb38] ERROR - [Req#3a351/Transcode/4d3af795-8bfc-4079-ae72-00d116742299/4d7e7d20-9fe6-4e55-80ae-166d5c930733] [mpeg2video @ 0x7f286026d640] Invalid frame dimensions 0x0.
Apr 17, 2023 20:52:21.512 [0x7f0eebcb2b38] ERROR - [Req#3a352/Transcode/4d3af795-8bfc-4079-ae72-00d116742299/4d7e7d20-9fe6-4e55-80ae-166d5c930733] [mpeg2video @ 0x7f286026d640] Invalid frame dimensions 0x0.
Apr 17, 2023 20:52:21.514 [0x7f0eef747b38] ERROR - [Req#3a353/Transcode/4d3af795-8bfc-4079-ae72-00d116742299/4d7e7d20-9fe6-4e55-80ae-166d5c930733] [mpeg2video @ 0x7f286026d640] Invalid frame dimensions 0x0.
Apr 17, 2023 20:52:21.515 [0x7f0ef1072b38] ERROR - [Req#3a354/Transcode/4d3af795-8bfc-4079-ae72-00d116742299/4d7e7d20-9fe6-4e55-80ae-166d5c930733] [mpeg2video @ 0x7f286026d640] Invalid frame dimensions 0x0.
Apr 17, 2023 20:52:21.523 [0x7f0eef13eb38] ERROR - [Req#3a355/Transcode/4d3af795-8bfc-4079-ae72-00d116742299/4d7e7d20-9fe6-4e55-80ae-166d5c930733] [mpeg2video @ 0x7f286026d640] Invalid frame dimensions 0x0.
Apr 17, 2023 20:52:21.547 [0x7f0eee344b38] ERROR - [Req#3a356/Transcode/4d3af795-8bfc-4079-ae72-00d116742299/4d7e7d20-9fe6-4e55-80ae-166d5c930733] [mpeg2video @ 0x7f286026d640] Invalid frame dimensions 0x0.
Apr 17, 2023 20:52:21.587 [0x7f0eeef3bb38] ERROR - [Req#3a357/Transcode/4d3af795-8bfc-4079-ae72-00d116742299/4d7e7d20-9fe6-4e55-80ae-166d5c930733] [mpeg2video @ 0x7f286026d640] Invalid frame dimensions 0x0.
Apr 17, 2023 20:52:21.588 [0x7f0eebcb2b38] ERROR - [Req#3a358/Transcode/4d3af795-8bfc-4079-ae72-00d116742299/4d7e7d20-9fe6-4e55-80ae-166d5c930733] [mpeg2video @ 0x7f286026d640] Invalid frame dimensions 0x0.
Apr 17, 2023 20:52:21.603 [0x7f0eef747b38] ERROR - [Req#3a359/Transcode/4d3af795-8bfc-4079-ae72-00d116742299/4d7e7d20-9fe6-4e55-80ae-166d5c930733] [mpeg2video @ 0x7f286026d640] Invalid frame dimensions 0x0.
Apr 17, 2023 20:52:21.659 [0x7f0ef1072b38] ERROR - [Req#3a35a/Transcode/4d3af795-8bfc-4079-ae72-00d116742299/4d7e7d20-9fe6-4e55-80ae-166d5c930733] [mpeg2video @ 0x7f286026d640] Invalid frame dimensions 0x0.
Apr 17, 2023 20:52:21.660 [0x7f0eef13eb38] ERROR - [Req#3a35b/Transcode/4d3af795-8bfc-4079-ae72-00d116742299/4d7e7d20-9fe6-4e55-80ae-166d5c930733] [mpeg2video @ 0x7f286026d640] Invalid frame dimensions 0x0.
Apr 17, 2023 20:52:21.858 [0x7f0eeef3bb38] ERROR - [Req#3a35c/Transcode/4d3af795-8bfc-4079-ae72-00d116742299/4d7e7d20-9fe6-4e55-80ae-166d5c930733] [mpeg2video @ 0x7f286026d640] Invalid frame dimensions 0x0.
Apr 17, 2023 20:52:23.363 [0x7f0eef341b38] ERROR - [Req#3a2fa/Grabber/5fc76e33e06f4d002d64116e-5fc705f1104230002d14da44-ur0f3rawijlxsx900r96vbkw] Unknown metadata type:
Apr 17, 2023 20:53:32.375 [0x7f0ef002db38] WARN - [Req#3ad9d/Live/4d3af795-8bfc-4079-ae72-00d116742299] Failed to find consumer
Apr 17, 2023 20:53:32.376 [0x7f0ef1072b38] WARN - [Req#3adb4/Live/4d3af795-8bfc-4079-ae72-00d116742299] Failed to find consumer
Apr 17, 2023 20:53:32.379 [0x7f0eef13eb38] WARN - [Req#3ade8/Live/4d3af795-8bfc-4079-ae72-00d116742299] Failed to find consumer
Apr 17, 2023 20:53:32.453 [0x7f0ef8df3b38] ERROR - [TranscodeOutputStream] Session appears to have died from under us
Apr 17, 2023 20:59:59.149 [0x7f0ef2fe8b38] INFO - Library section 6 (Serien) will be updated because of a change in "/media/christoph/tv_shows/Futurama (1999)/Season 10/Futurama (1999) - S10E06 - Saturday Morning Fun Pit.ts"
Apr 17, 2023 21:00:00.757 [0x7f0eefdffb38] WARN - [Grabber/b36ddb63b07c1b8efe167c4aa85aba80ab80bc7a] MDE: unable to find a working transcode profile for video stream
Apr 17, 2023 21:00:00.838 [0x7f0eedb1fb38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 21:00:00.838 [0x7f0eedb1fb38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F614ab2ad70e077d5925d3a40
Apr 17, 2023 21:00:00.838 [0x7f0eedb1fb38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 21:00:00.840 [0x7f0eed313b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 21:00:00.840 [0x7f0eed313b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F5fc68f8b843f5c002dc52ebd
Apr 17, 2023 21:00:00.840 [0x7f0eed313b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 21:00:00.842 [0x7f0eef341b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 21:00:00.842 [0x7f0eef341b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F6070c2c945c6ab002d9f370b
Apr 17, 2023 21:00:00.842 [0x7f0eef341b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 21:00:00.847 [0x7f0eedb1fb38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 21:00:00.847 [0x7f0eedb1fb38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F5fc693631a65df002dd2add1
Apr 17, 2023 21:00:00.847 [0x7f0eedb1fb38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 21:00:00.864 [0x7f0eed313b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 21:00:00.864 [0x7f0eed313b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F5fc692a3a7560c002d58618a
Apr 17, 2023 21:00:00.864 [0x7f0eed313b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 21:00:02.381 [0x7f0eed110b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 21:00:02.381 [0x7f0eed110b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F614ab2ad70e077d5925d3a40
Apr 17, 2023 21:00:02.381 [0x7f0eed110b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 21:00:02.385 [0x7f0eed313b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 21:00:02.385 [0x7f0eed313b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F5fc68f8b843f5c002dc52ebd
Apr 17, 2023 21:00:02.385 [0x7f0eed313b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 21:00:02.387 [0x7f0eedb1fb38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 21:00:02.387 [0x7f0eedb1fb38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F6070c2c945c6ab002d9f370b
Apr 17, 2023 21:00:02.387 [0x7f0eedb1fb38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 21:00:02.392 [0x7f0eed110b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 21:00:02.392 [0x7f0eed110b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F5fc693631a65df002dd2add1
Apr 17, 2023 21:00:02.392 [0x7f0eed110b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 21:00:02.416 [0x7f0eed313b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 21:00:02.416 [0x7f0eed313b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F5fc692a3a7560c002d58618a
Apr 17, 2023 21:00:02.416 [0x7f0eed313b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 21:00:04.203 [0x7f0eed110b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 21:00:04.203 [0x7f0eed110b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F614ab2ad70e077d5925d3a40
Apr 17, 2023 21:00:04.203 [0x7f0eed110b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 21:00:04.203 [0x7f0eed313b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 21:00:04.203 [0x7f0eed313b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F6070c2c945c6ab002d9f370b
Apr 17, 2023 21:00:04.203 [0x7f0eed313b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 21:00:04.205 [0x7f0eef341b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 21:00:04.205 [0x7f0eef341b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F5fc68f8b843f5c002dc52ebd
Apr 17, 2023 21:00:04.205 [0x7f0eef341b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 21:00:04.216 [0x7f0eed110b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 21:00:04.216 [0x7f0eed110b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F5fc693631a65df002dd2add1
Apr 17, 2023 21:00:04.216 [0x7f0eed110b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 21:00:04.231 [0x7f0eed313b38] ERROR - downloadContainer: expected MediaContainer element, found html
Apr 17, 2023 21:00:04.231 [0x7f0eed313b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fmovie%2F5fc692a3a7560c002d58618a
Apr 17, 2023 21:00:04.231 [0x7f0eed313b38] ERROR - Subscription: Error refreshing sub: No container found
Apr 17, 2023 21:00:22.765 [0x7f0ef0293b38] ERROR - [Grabber/b36ddb63b07c1b8efe167c4aa85aba80ab80bc7a/CreditsDetectionManager] BufferingLineReader: failed to read line (error: -1)
Complete logs means attaching the full zip file that was downloaded into a reply, otherwise I have to ask several questions and then may still need to see the full zip to understand what is happening. (Plex Employees usually won’t help or reply if not present)
  1. Server Version
  2. OS Version, Server or Workstation. Did you load a GUI.
  3. Client being used for testing and version
  4. CPU
  5. Location of transcoder folder
  6. Are you running Plex native, docker, snap, VM.
  7. Storage, internal, external, NAS
    8 Country (Different broadcast standards)
Your choice of using /media can create permission problems.
Tip #26 Linux Tips - #26 by ChuckPa
Find the Codecs directory, default path is: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs
Stop Plex, don’t remove the .device.id file but delete the contents of the subdirectory, then restart Plex and try again.
One additional request: It appears that your logs may be ā€œinfoā€ level. Would you please switch to debug level so that they produce more information for troubleshooting? Don’t check ā€œverboseā€ - it is too much info and causes the logs to roll off to quickly. Note that at debug level your logs may only go back a day or so, therefore it is important to capture logs fairly soon after the issue happens.
  1. Log in to Plex Web
  2. Go to Settings → (Your server name) → General
  3. Make sure the ā€œShow Advancedā€ button (image) has been clicked.
  4. Make sure that the ā€œEnable Plex Media Server debug loggingā€ is checked and that ā€œEnable Plex Media Server vebose loggingā€ is UNchecked.
  5. Click ā€œSave Changesā€
  6. Restart your Plex Media Server
I tried again and I can reproduce my issue for live TV (which I think is related to recordings with 0 Bytes)
here is the Set of Logs in debug mode for my tries between 17:45 and 17:50 where I tried to start live TV several times and it only worked after a few attempts.
Plex Media Server Logs_2023-04-19_17-53-38.zip (1.3 MB)
I use Plex native installed on Ubuntu 22.04
plexmediaserver (1.32.0.6950-8521b7d99) wird eingerichtet ...
PlexMediaServer install: PlexMediaServer-1.32.0.6950-8521b7d99 - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install:   Installation Type:   Update
PlexMediaServer install:   Process Control:     systemd
PlexMediaServer install:   Plex User:           plex
PlexMediaServer install:   Plex Group:          plex
PlexMediaServer install:   Video Group:         render
PlexMediaServer install:   Metadata Dir:        /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install:   Temp Directory:      /tmp
PlexMediaServer install:   Lang Encoding:       en_US.UTF-8
PlexMediaServer install:   Processor:           Intel(R) Core(TM) i7-6700T CPU @ 2.80GHz
PlexMediaServer install:   Intel i915 Hardware: Found
PlexMediaServer install:   Nvidia GPU card:     Not Found
PlexMediaServer install: Completing final configuration.
PlexMediaServer install: Starting Plex Media Server.
PlexMediaServer install: PlexMediaServer-1.32.0.6950-8521b7d99 - Installation successful.  Errors: 0, Warnings: 0
storage is on an internal NVME drive with 2 TB, and a lot of free space…
I’m located in Germany and use Vodafone Kabel DVB-C receivers.
As client I use Plex for Windows, Version 1.67.2.3705-db506a00 on Windows 10
BTW the download link from the Desktop App does not work correctly:
It redirects me to https://192-168-246-131.8e3925297xxxxx.plex.direct:32400/diagnostics/logs?X-Plex-Token=xxx which does not work…
I see your transcoder failing during that time period with a codec error. Have you tried the recommendation above by @pl_5309 to stop your plex server, delete the codecs, and start plex server? That is my first go-to when I’m having recording problems.
Apr 19, 2023 17:49:11.606 [0x7f5a1fc21b38] ERROR - [Req#1880/Transcode/fqwgsojjimeqksau9yiyjb3x/a2ff5eb4-76c6-4d45-9b6d-86910263bdca] [segment @ 0x7f754eefc080] dimensions not set
Apr 19, 2023 17:49:11.607 [0x7f5a1fa16b38] ERROR - [Req#1884/Transcode/fqwgsojjimeqksau9yiyjb3x/a2ff5eb4-76c6-4d45-9b6d-86910263bdca] Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
Apr 19, 2023 17:49:11.608 [0x7f5a215b7b38] ERROR - [Req#1885/Transcode/fqwgsojjimeqksau9yiyjb3x/a2ff5eb4-76c6-4d45-9b6d-86910263bdca] Error initializing output stream 0:1 --
Apr 19, 2023 17:49:11.609 [0x7f5a21bfab38] ERROR - [Req#1886/Transcode/fqwgsojjimeqksau9yiyjb3x/a2ff5eb4-76c6-4d45-9b6d-86910263bdca]
Apr 19, 2023 17:49:11.612 [0x7f5a241f9b38] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 13342 is 1 (failure)
I don’t have your tuner and I’m not sure that I found the tech specs for the correct device. Does it connect to your Plex server hardware via USB? Some of the information in the Plex Tuner Service log for your tuner is different than my HDHR tuner, and I don’t know if I’m interpreting it correctly. I do see some messages that look odd to me, but I don’t know if these are the cause of the issue, or the result of the issue:
Apr 19, 2023 17:49:11.616 [0x7ff8ebcabb38] WARN - [E] http_streamer_t::handle_read: read_error: End of file (2)
Apr 19, 2023 17:49:11.616 [0x7ff8eb89db38] WARN - [E] http_streamer_t: http write error
and a bit earlier:
Apr 19, 2023 17:35:02.617 [0x7ff8ebcabb38] WARN - [E] web_service_t::get_device_status. get_device_info returned error for device dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3
With your tuner, are you able to check that it is working normally from OUTSIDE of Plex?
thanks for the tipp to delete / reinstall the codecs.
after that it looks like I don’t get the failure at starting live tv viewing any more.
regarding recording I’ll watch if it is also fixed…
@hokierulz @pl_5309
thank you very much for looking into it.
yes, my DVB-C devices are connected by USB to the machine running PLEX.
Outside of PLEX all works fine (tested with Kaffeine)
However, after deleting the codecs it seems to be better. Iet’s see if the recording issues are also gone (as the live-tv issue)…
I have to add an interesting note: the 264 encoder I deleted was not restored in the directory, and the quality of transcoding went really bad. After I restored the old file liblibx264_encoder.so the quality was fine again but also the problem of failure at starting live TV watching was back…
unfortunately I don’t really know what happens there, or where these files come from and why…
You are experiencing a DNS and DNS Rebinding issue that is probably interfering with the download of the codecs.
You have HW transcoding turned on but it doesn’t seem to be activating properly. Just a general observation is that the server appears busy and Plex is struggling with the database access. I would run a manual optimize and if is large or very old consider doing a dump and load to reorg the data.
Final concern was the boost messages with regard to /media, is this local or network storage?
@pl_5309 thank you for taking a closer look.
But how do you come to the conclusion about a DNS rebinding problem?
$ resolvectl
Global
       Protocols: -LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported
resolv.conf mode: stub
Link 2 (eno1)
    Current Scopes: DNS
         Protocols: +DefaultRoute +LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported
Current DNS Server: 192.168.246.4
       DNS Servers: 192.168.246.4
        DNS Domain: fritz.box
and my router which is 192.168.246.4 is configured to use Google DNS servers…
I also don’t get how I can check if the hardware encoding is properly used.
I have all the necessary drivers in place as vainfo shows and I recognize a significant difference in processor load on transcoding.
~$ vainfo
libva info: VA-API version 1.14.0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_14
libva info: va_openDriver() returns 0
vainfo: VA-API version: 1.14 (libva 2.12.0)
vainfo: Driver version: Intel iHD driver for Intel(R) Gen Graphics - 22.3.1 ()
vainfo: Supported profile and entrypoints
      VAProfileNone                   : VAEntrypointVideoProc
      VAProfileNone                   : VAEntrypointStats
      VAProfileMPEG2Simple            : VAEntrypointVLD
      VAProfileMPEG2Simple            : VAEntrypointEncSlice
      VAProfileMPEG2Main              : VAEntrypointVLD
      VAProfileMPEG2Main              : VAEntrypointEncSlice
      VAProfileH264Main               : VAEntrypointVLD
      VAProfileH264Main               : VAEntrypointEncSlice
      VAProfileH264Main               : VAEntrypointFEI
      VAProfileH264Main               : VAEntrypointEncSliceLP
      VAProfileH264High               : VAEntrypointVLD
      VAProfileH264High               : VAEntrypointEncSlice
      VAProfileH264High               : VAEntrypointFEI
      VAProfileH264High               : VAEntrypointEncSliceLP
      VAProfileVC1Simple              : VAEntrypointVLD
      VAProfileVC1Main                : VAEntrypointVLD
      VAProfileVC1Advanced            : VAEntrypointVLD
      VAProfileJPEGBaseline           : VAEntrypointVLD
      VAProfileJPEGBaseline           : VAEntrypointEncPicture
      VAProfileH264ConstrainedBaseline: VAEntrypointVLD
      VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
      VAProfileH264ConstrainedBaseline: VAEntrypointFEI
      VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP
      VAProfileVP8Version0_3          : VAEntrypointVLD
      VAProfileHEVCMain               : VAEntrypointVLD
      VAProfileHEVCMain               : VAEntrypointEncSlice
      VAProfileHEVCMain               : VAEntrypointFEI
I use /media as local storage on an NVME disk. that came from a misunderstanding :wink: and I’m aware of the file permission issues. As it works at least sometimes, I would assume, that this can not be a problem.
I optimized the DB now. lets see, if that as an effect…
DNS or you are inadvertently blocking the Plex pubsub servers - could be a cert issue if using custom cert and needs updating for SSL3.
Video Driver - Plex has decided to package the driver and not depend on the OS installed ones. Solves some problems but creates others. It sees your GPU, just doesn’t engage it. Not a long term solution but you could drop this into your Preferences.xml to see if the behavior changes.
VaapiDriver="i965"
You will want to check the dashboard while something is playing to see if (HW) is next to any transcode. Also puzzled why the Desktop client would be asking for a transcode in the first place.
[Req#10ad/Transcode] Streaming Resource: Reached Decision id=2754 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=3949 part=(id=3960 decision=transcode container=mkv protocol=http streams=(Video=(id=9364 decision=copy width=720 height=576) Audio=(id=9365 decision=copy channels=2 rate=48000))))
Disk - I think you already upgraded past the version that had this problem:
WARN - Error scanning directory, we'll skip and continue: boost::filesystem::last_write_time: No such file or directory
@pl_5309 thanks for your hints.
I added the configuration, let’s wait and see.
I do see ā€œhwā€ next to the transcoding information in the dashboard.
And I was also wondering, why the windows desktop app sometimes goes for transcoding instead of direct play…
Unfortunately, I have no idea how to act on the DNS issue. Also in my browser this address does not connect to anywhere, but I don’t block anything in my firewall. Where should it connect to ? Do you have any tips on how to proceed here?
However, I can connect from anywhere to my server through https://app.plex.tv/desktop/#!/settings… so NAT and Port-forward do work correctly.
Could it be an issue, that I used a different port than 32400 for forwarding?
I also installed the new version from yesterday and I’ll report if things change.
Vorbereitung zum Entpacken von .../plexmediaserver_1.32.0.6973-a787c5a8e_amd64.deb ...
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Pre-installation Validation complete.
Entpacken von plexmediaserver (1.32.0.6973-a787c5a8e) über (1.32.0.6950-8521b7d99) ...
plexmediaserver (1.32.0.6973-a787c5a8e) wird eingerichtet ...
PlexMediaServer install: PlexMediaServer-1.32.0.6973-a787c5a8e - Installation starting.
PlexMediaServer install: PlexMediaServer-1.32.0.6973-a787c5a8e - Installation successful.  Errors: 0, Warnings: 0
today in the morning 4:32 it happened again: only a few seconds recorded, then recording stopped. it shows 9 seconds, but it does not start playing. the file on disk shows 946580 Bytes only.
maybe the recording interfered with the maintenance window (from 4-5)? but the other occasions where not at that time-period…
here are the logs with debug enabled, maybe you can see something there at today morning 4:32…
Plex Media Server Logs_2023-04-22_11-21-28.zip (5.2 MB)
