Can not set series recordings, only single airings
For whatever reason, scheduled recordings is only showing one-time recordings and not series recordings. At first I thought the entire DVR function was broken on my installation, but it turns out it just refuses to set/record any series. So, for the moment, the only way I can record is by setting individual episodes to record.
Any insight on this? I can’t for the life of me find any settings that are improperly set that would be causing this issue.
SOLVED: Another user had a similar issue and mentioned a guide refresh seemed to work. It did. I’m not sure why the guide isn’t working after each install, but a refresh does seem to get things back on track.
