Can not view movie library after update. Please help!
Server is version 1.4.3.3433, web app is version 3.0.1.
Ever since my server updated I can not view my movie library on the server directly. It does not matter what view I try. I can view / play them just fine on the android mobile and Xbox one, and web apps. And my friends can view the library and play items with no issue. I can also edit movies if I search manually for them.
I have tried multiple times to restart the service, the computer, refresh and update the library. All i get is this message…
My TV and Picture libraries all behave fine. The only thing I haven’t done is delete and re add the library. I want to avoid this if at all possible, because I have a ton of custom sort titles that I relay don’t want to re-do.
Please Help! HOW DO I FIX THIS?!?
SAME HERE! My music library behaves fine as well, so does my TV Shows (though I only have one season of Archer in there.) I’m at about 650 movies, is there a limit?
