Can somebody help me with Sonic Sage's API key?
Hey there guys,
Quick and easy. How/Where can I tell Plexamp to optain my OpenAI API key? I went 13 times through Plexamp’s settings, but couldn’t find a tab where to add my newly created API key? Am I too blind? Too old? Too drunk?
Any help on how to get this working would be huge!
Got it solved!
For fellow errorers: The ChatGPT account’s email address (you might have to create an openAI account) must match the one from your Tidal subscription! (Which must eventually match your Plex email address as well, so long story short: Use the same email address for all Plex services ^^)
Not true! Thy founder has spoken ye treuth!
Btw I love how engaged you are with Plexamp, even though you might have a hell of other stuff to do. You can see just from your engagement with Plexamp, that you’re most likely a gigantomanic audiophile yourself ^^ :heart:
Not true :sweat_smile:
The emails can be different.
TIDAL account linkage is set up via https://clients.plex.tv/users/other-services
OpenAI account linkage is set up in Plexamp in Settings > Advanced > Sonic Sage.
B…b…but the setting only appeared after I changed openAI’s email address :weary: Or in this instance created a new account with the same email address as my tidal address :thinking:
I wonder what the issue was then there :smile: Because the option to add the API key in Plexamp’s settings 100% wasn’t existing for a while :man_shrugging:
Maybe I was really just too darn blind :sweat_smile:
Coincidence. It appears after your TIDAL account is linked successfully and Plexamp picks up on this.
Lol! Jeez, okay my assumption might have been a bit too quick then :grin: Alright, thank you for clarifying this, commander :raised_hand_with_fingers_splayed:
