What Am I doing wrong here?
2016-10-26 01:22:05,868 (2698) : INFO (core:349) - Starting framework core - Version: 2.6.3, Build: 24ffd60 (Mon Sep 12 15:27:43 UTC 2016)
2016-10-26 01:22:05,869 (2698) : DEBUG (core:361) - Using the standard policy
2016-10-26 01:22:05,871 (2698) : DEBUG (core:450) - Starting runtime component.
2016-10-26 01:22:05,878 (2698) : DEBUG (core:450) - Starting caching component.
2016-10-26 01:22:05,880 (2698) : DEBUG (core:450) - Starting data component.
2016-10-26 01:22:05,881 (2698) : DEBUG (core:450) - Starting networking component.
2016-10-26 01:22:05,882 (2698) : DEBUG (networking:284) - Loaded HTTP cookies
2016-10-26 01:22:05,887 (2698) : DEBUG (networking:452) - Setting the default network timeout to 20.0
2016-10-26 01:22:05,888 (2698) : DEBUG (core:450) - Starting localization component.
2016-10-26 01:22:05,890 (2698) : INFO (localization:409) - Setting the default locale to en-us
2016-10-26 01:22:05,891 (2698) : DEBUG (core:450) - Starting messaging component.
2016-10-26 01:22:05,892 (2698) : DEBUG (core:450) - Starting debugging component.
2016-10-26 01:22:05,894 (2698) : DEBUG (core:450) - Starting services component.
2016-10-26 01:22:05,894 (14a4) : DEBUG (networking:166) - Requesting 'http://127.0.0.1:32400/system/messaging/clear_events/com.plexapp.plugins.fmoviesto'
2016-10-26 01:22:05,895 (2698) : DEBUG (core:450) - Starting myplex component.
2016-10-26 01:22:05,898 (2698) : DEBUG (core:450) - Starting notifications component.
2016-10-26 01:22:06,345 (2698) : DEBUG (accessor:68) - Creating a new model access point for provider com.plexapp.plugins.fmoviesto in namespace 'metadata'
2016-10-26 01:22:06,364 (2698) : DEBUG (networking:166) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/resourceHashes'
2016-10-26 01:22:06,482 (2698) : DEBUG (runtime:1117) - Created a thread named 'load_all_services'
2016-10-26 01:22:06,482 (31e0) : DEBUG (services:265) - Plug-in is not daemonized - loading services from system
2016-10-26 01:22:06,486 (2698) : DEBUG (runtime:1117) - Created a thread named 'get_server_info'
2016-10-26 01:22:06,487 (2c28) : DEBUG (networking:166) - Requesting 'http://127.0.0.1:32400'
2016-10-26 01:22:06,487 (31e0) : DEBUG (networking:166) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_'
2016-10-26 01:22:06,487 (2698) : DEBUG (core:150) - Finished starting framework core
2016-10-26 01:22:06,493 (2698) : DEBUG (core:560) - Loading plug-in code
2016-10-26 01:22:06,509 (2698) : CRITICAL (core:574) - Exception while loading code (most recent call last):
File "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-24ffd60\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\core.py", line 563, in load_code
self.init_code = self.loader.load(self.init_path, elevated, use_xpython = Framework.constants.flags.use_xpython in self.sandbox.flags)
File "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-24ffd60\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\code\loader.py", line 47, in load
code = self.compile(str(source), str(uni(filename)), elevated)
File "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-24ffd60\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\code\loader.py", line 52, in compile
return RestrictedPython.compile_restricted(source, name, 'exec', elevated=elevated)
File "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-24ffd60\Framework.bundle\Contents\Resources\Platforms\Shared\Libraries\RestrictedPython\RCompile.py", line 115, in compile_restricted
gen.compile()
File "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-24ffd60\Framework.bundle\Contents\Resources\Platforms\Shared\Libraries\RestrictedPython\RCompile.py", line 68, in compile
tree = self._get_tree()
File "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-24ffd60\Framework.bundle\Contents\Resources\Platforms\Shared\Libraries\RestrictedPython\RCompile.py", line 59, in _get_tree
tree = self.parse()
File "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-24ffd60\Framework.bundle\Contents\Resources\Platforms\Shared\Libraries\RestrictedPython\RCompile.py", line 56, in parse
return niceParse(self.source, self.filename, self.mode)
File "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-24ffd60\Framework.bundle\Contents\Resources\Platforms\Shared\Libraries\RestrictedPython\RCompile.py", line 38, in niceParse
compile(source, filename, mode)
File "C:\Users\LinusOS400\AppData\Local\Plex Media Server\Plug-ins\fmoviesto.bundle\Contents\Code\__init__.py", line 25
ObjectContainer.title1 = TITLE
IndentationError: unexpected indent
2016-10-26 01:22:06,516 (2c28) : DEBUG (core:538) - Machine identifier is e327bf8bbc80129758b4241b8db013dafceeb668
2016-10-26 01:22:06,516 (2c28) : DEBUG (core:539) - Server version is 1.1.4.2757-24ffd60
2016-10-26 01:22:07,006 (31e0) : DEBUG (services:362) - Loaded services
2016-10-26 01:22:07,022 (1778) : DEBUG (services:438) - No shared code to load
