Can we download logs directly into our device?
Redmi Note 8
Android 11
Miui 12.5
Maybe i am missing it, but i don’t find the option to directly download the logs into my device…
Here are the choices i have :
Is it something possible ?
On iOS I can share the files to the native Files app and select the phone’s local storage as target.
Not sure if there’s a corresponding solution for Android… but with its millions of options there should be a way to do that.
I agree that there should be a millions ways to do it :smiley:
But see the options here, none of them propose to download the file directly…
I‘m no expert when it comes to Android… from what I could find in the internet it seems there’s no native OS features to do that. But there’s other Android apps that’ll show up in the sharing pane and allow you to save a file to the local storage of your phone.
Seems like there’s a number of such apps. I have no idea which one is particularly good/bad.
Thank you for pointing me there I’ll try it !
Also, maybe having a native option in Plexamp like : Download Logs (not Share Logs) would be more than helpfull :slight_smile:
