Can you help me on HW Transcoding?
Server Version#: Latest
Player Version#: Latest
Hello,
I try to use HW transcoding, but no luck sadly.
My linux version is headless Debian 11, cpu i5 12500.
Hardware transcoding is already opened in transcoding settings.
I already tried adding lines to Preference.xml for qsv, not working.
  1. You don’t need to add anything to Preferences.xml for QSV support.
    If you’ve added something – remove it.
  2. can you make certain DEBUG logging is enabled (SAVE if you make changes)
  3. Attempt a transcode of content then stop
  4. Download the logs ZIP file
  5. Attach here
  6. I’ll look and see what’s going on.
  1. I was added “HardwareDevicePath=”/dev/dri/renderD128" " this line, deleted right now.
  2. Adding attached logs, Plex Transcoder Statistics.log is the latest one for transcoding. (I hope there is no info shared in logs about server)
Plex Media Server Logs_2023-02-28_08-02-10.zip (4.2 MB)
Your logs show me that there is nothing being seen.
This is a big problem because the i5-12500 (AlderLake) is supported.
eb 27, 2023 14:36:22.738 [0x7f657887eb38] DEBUG - [Req#c4/Transcode] Codecs: testing h264_vaapi (encoder)
Feb 27, 2023 14:36:22.738 [0x7f657887eb38] DEBUG - [Req#c4/Transcode] Codecs: hardware transcoding: testing API vaapi
Feb 27, 2023 14:36:22.738 [0x7f657887eb38] ERROR - [Req#c4/Transcode] [FFMPEG] - No VA display found for device /dev/dri/renderD128.
Feb 27, 2023 14:36:22.738 [0x7f657887eb38] DEBUG - [Req#c4/Transcode] Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Invalid argument
Feb 27, 2023 14:36:22.738 [0x7f657887eb38] DEBUG - [Req#c4/Transcode] Could not create hardware context for h264_vaapi
Feb 27, 2023 14:36:22.738 [0x7f657887eb38] DEBUG - [Req#c4/Transcode] Codecs: testing h264_nvenc (encoder)
Feb 27, 2023 14:36:22.738 [0x7f657887eb38] DEBUG - [Req#c4/Transcode] Codecs: hardware transcoding: testing API nvenc
Feb 27, 2023 14:36:22.738 [0x7f657887eb38] ERROR - [Req#c4/Transcode] [FFMPEG] - Cannot load libcuda.so.1
Feb 27, 2023 14:36:22.738 [0x7f657887eb38] ERROR - [Req#c4/Transcode] [FFMPEG] - Could not dynamically load CUDA
I am busy (personal life) today. I will be able to look further at this tonight when I return.
Thank you man. I am waiting a response from you :slight_smile:
Today, Engineering released a whole bunch of fixes in PlexPass release.
Have you had opportunity to try it?
Seems there is no update for server ? 1.31.1.6733
Mar 01, 2023 16:32:37.861 [0x7fe2f2556b38] DEBUG - [Req#17195/Transcode] TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Mar 01, 2023 16:32:37.861 [0x7fe2f2556b38] DEBUG - [Req#17195/Transcode] [Universal] Using local file path instead of URL: /home/ergunaksoy/Filmler/Avatar (2009)/Avatar (2009) Remux-1080pAVC DTS-HD MA [EN+AR+ZH+CS+DA+NL+FI+FR+DE+EL+HU+IS+IT+JA+KO+NO+PL+PT+RO+RU+ES+SV+TH].mkv
Mar 01, 2023 16:32:37.861 [0x7fe2f2556b38] DEBUG - [Req#17195/Transcode] TPU: hardware transcoding: final decoder: , final encoder:
Tried right now, seems like this.
Plex Media Server Logs_2023-03-01_16-33-43.zip (4.2 MB)
Okey sorry, I updated my plex server to 1.31.2.6739, my new logs:
starts with 16.40-41 times:
Plex Media Server Logs_2023-03-01_16-41-24.zip (3.7 MB)
Does your bios have the gpu disabled?
there is something seriously wrong.
It’s not an AlderLake problem. If it were then everyone would complain.
The only thing I can think of to try iss:
  1. Stop Plex
  2. cd “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Drivers”
  3. If you don’t have a ‘Drivers’ directory then PMS has NEVER detected the GPU. That’s a problem with the computer config (BIOS)
  4. If you do have ‘Drivers’, then delete everything in there (let’s start over)
  5. Please let me know what happens. (I wish I could help you more but timezones are working against us. I’d offer to arrange 1-1 for this)
There is only /var/lib/plexmediaserver/Library/Application Support/ , no Plex Media Server and no Drivers section.
It would be better If you can take a look from putty, because if I write this command i see my gpu is in.
thank you very much
did you forget me ? :frowning:
No, not forgotten. Busy? YES.
If you have no “Application Support/Plex Media Server” directory
then Plex isn’t starting up --OR-- the PLEX_MEDIA_APPLICATION_SUPPORT_DIR was moved.
Did you customize it?
Nope, I did not, would you like to check my server ?
I think I might need to. Do you have teamviewer ?
I can give you ip and pass directly to my server, no problem
I will send you a PM. We can discuss further in Private.
thank you very much
