Server Version#: Plex Media Server v1.18.2.2058-e67a4e892 - Synology DS412+ x86_64 - build: linux-x86_64 synology - GMT 01:00
From one day to another I have problems accessing my local Plex server. My Synology is located at 192.168.1.24. I’m not using any VPN or other fancy network configuration in my LAN. Plex is configured to listen to port 32400.
From within my own network trying to reach Plex from my laptop (http://192.168.1.24:32400/web/index.html - also tried https://), I end up in an ERR_TIMED_OUT (using Chrome with or without incognito and Safari). I’ve looked through the logs but I cannot find anything that stands out - except perhaps for this entry:
Dec 31, 2019 23:20:37.202 [0x7fc4a6bd6700] ERROR - Error issuing curl_easy_perform(handle): 7
Dec 31, 2019 23:20:37.202 [0x7fc4a6bd6700] WARN - HTTP error requesting POST http://127.0.0.1:32600/devices/discover (0, No error) (Failed to connect to 127.0.0.1 port 32600: Connection refused)
(what is it doing with port 32600?).
Anyways. Plex process is running:
ps -aux | grep -i plex
plex 12970 0.1 0.3 1089040 3164 ? Sl 2019 0:02 /var/packages/Plex Media Server/target/Plex Media Server
admin 19379 0.0 0.0 23132 964 pts/9 S+ 00:04 0:00 grep --color=auto -i plex
Looking at netstat there’s a lot of CLOSE_WAIT entries (for IPv6?) and one LISTEN for tcp6 (encompassing also IPv4? Not sure here).
(192.168.1.105 is my laptop I’m using to try to access Plex).
netstat -an | grep 32400
tcp 0 0 192.168.1.24:32400 192.168.1.1:57255 SYN_RECV
tcp 0 0 192.168.1.24:32400 192.168.1.105:57249 SYN_RECV
tcp 0 0 192.168.1.24:32400 192.168.1.105:57257 SYN_RECV
tcp 0 0 192.168.1.24:32400 192.168.1.105:57233 SYN_RECV
tcp 0 0 192.168.1.24:32400 192.168.1.1:57250 SYN_RECV
tcp 0 0 192.168.1.24:32400 192.168.1.105:57254 SYN_RECV
tcp 0 0 192.168.1.24:32400 192.168.1.105:57236 SYN_RECV
tcp 0 0 192.168.1.24:32400 192.168.1.105:57240 SYN_RECV
tcp 0 0 192.168.1.24:32400 192.168.1.1:57259 SYN_RECV
tcp6 129 0 :::32400 :::* LISTEN
tcp6 746 0 192.168.1.24:32400 192.168.1.1:55333 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55181 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55007 CLOSE_WAIT
tcp6 745 0 192.168.1.24:32400 192.168.1.105:55012 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55966 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:56034 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55493 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:54712 CLOSE_WAIT
tcp6 746 0 192.168.1.24:32400 192.168.1.1:55919 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:56059 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:55984 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:55663 CLOSE_WAIT
tcp6 746 0 192.168.1.24:32400 192.168.1.1:55975 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:56004 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:55812 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:55682 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:55948 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:55073 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55925 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:55795 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55612 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:55990 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55972 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:56029 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:55947 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:56069 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55013 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:54579 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:55951 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55165 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55474 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:54806 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55974 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:54887 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:55095 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:56005 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:55074 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:56024 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55163 CLOSE_WAIT
tcp6 745 0 192.168.1.24:32400 192.168.1.105:55611 CLOSE_WAIT
tcp6 745 0 192.168.1.24:32400 192.168.1.105:55760 CLOSE_WAIT
tcp6 746 0 192.168.1.24:32400 192.168.1.1:55166 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55631 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:54558 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:56019 CLOSE_WAIT
tcp6 745 0 192.168.1.24:32400 192.168.1.105:54871 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:54787 CLOSE_WAIT
tcp6 1 0 192.168.1.24:32400 192.168.1.105:55047 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:54714 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:56052 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55962 CLOSE_WAIT
tcp6 746 0 192.168.1.24:32400 192.168.1.1:54565 CLOSE_WAIT
tcp6 618 0 192.168.1.24:32400 192.168.1.105:55046 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55776 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55332 CLOSE_WAIT
tcp6 745 0 192.168.1.24:32400 192.168.1.105:55961 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55494 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:56009 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:56020 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55182 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:56068 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55965 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:55398 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55348 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:56030 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55025 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:54866 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:55383 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:56038 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:55089 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:54788 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55761 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:54872 CLOSE_WAIT
tcp6 745 0 192.168.1.24:32400 192.168.1.105:54713 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55632 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:56073 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:56060 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55978 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55472 CLOSE_WAIT
tcp6 745 0 192.168.1.24:32400 192.168.1.105:55164 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55960 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:56018 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:55810 CLOSE_WAIT
tcp6 746 0 192.168.1.24:32400 192.168.1.1:55014 CLOSE_WAIT
tcp6 746 0 192.168.1.24:32400 192.168.1.1:55762 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:54580 CLOSE_WAIT
tcp6 746 0 192.168.1.24:32400 192.168.1.1:54873 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:56072 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:54803 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55024 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55610 CLOSE_WAIT
tcp6 746 0 192.168.1.24:32400 192.168.1.1:55475 CLOSE_WAIT
tcp6 446 0 192.168.1.24:32400 192.168.1.105:56003 CLOSE_WAIT
tcp6 618 0 192.168.1.24:32400 192.168.1.105:55923 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:55985 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55759 CLOSE_WAIT
tcp6 745 0 192.168.1.24:32400 192.168.1.105:55973 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55330 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:55400 CLOSE_WAIT
tcp6 745 0 192.168.1.24:32400 192.168.1.105:54563 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:55796 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55918 CLOSE_WAIT
tcp6 745 0 192.168.1.24:32400 192.168.1.105:55473 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55912 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:54564 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:54734 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:56065 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55777 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:56039 CLOSE_WAIT
tcp6 746 0 192.168.1.24:32400 192.168.1.1:54715 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:55953 CLOSE_WAIT
tcp6 745 0 192.168.1.24:32400 192.168.1.105:55331 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:54733 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:55384 CLOSE_WAIT
tcp6 746 0 192.168.1.24:32400 192.168.1.1:55613 CLOSE_WAIT
tcp6 161 0 192.168.1.24:32400 192.168.1.1:55664 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55977 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:56010 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:55347 CLOSE_WAIT
tcp6 745 0 192.168.1.24:32400 192.168.1.105:55917 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.105:56064 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:54888 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:55681 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:55926 CLOSE_WAIT
tcp6 518 0 192.168.1.24:32400 192.168.1.1:56035 CLOSE_WAIT
tcp6 1 0 192.168.1.24:32400 192.168.1.105:55924 CLOSE_WAIT
tcp6 746 0 192.168.1.24:32400 192.168.1.1:55963 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:55983 CLOSE_WAIT
tcp6 160 0 192.168.1.24:32400 192.168.1.105:56049 CLOSE_WAIT
I’ve tried restarting Plex. I’ve tried restarting my Synology DS. No avail. I’m out of ideas of what’s causing this. Any suggestions on what to try or what to look for?
Logs (1).zip (9.0 MB)
