Plex Media Server Not Running on Synology
Server Version#: 1.32.5.7349-7000
Player Version#: 1.75.0.3920-8b50876d
I see lots of things with Synology and Plex but I’m still having issues and not sure if anyone can help.
I have a Synology Nas - DS1819+. I have had it running for a while with plex without issue. It is currently running DSM 7.2-64570 Update 3. But this is fairly new as a troubleshooting option for this issue. It had been on a previous DSM 7.X version however I cannot remember the build.
I was trying to access plex on a PC using the above player version. It had the server as unavailable. I logged into my NAS. The package shows as “Manually Stopped”. I go to click run. It tries to start then stops. This just keeps happening and it never actually runs.
I update the build to the latest download. 1.32.5.7349-7000. The same thing continues.
The only “change” lately has been that the NAS was powered down incorrectly by someone unplugging it on accident.
Any help on how to get Plex back up and running on my Synology NAS?
Any help greatly appreciated!
Thanks,
Matt
This is fairly easy to get started.
  1. Open FileStation
  2. Navigate - PlexMediaServer/AppData/Plex Media Server
  3. Right-Click LogsCompress to Logs.zip
  4. when that finishes, download the ZIP file and upload (attach it) here with your next reply.
With that ZIP. we should be able to see what happened.
Logs.zip (4.4 MB)
Logs attached
@mgohring
Thank you.
Your Synology’s network configuration got all stupid.
It looks like either:
  1. A DHCP server is refreshing the IP address every few seconds
-OR-
  1. There is a loose connector – OR – damaged cable
Aug 02, 2023 21:27:39.526 [0x7f5667d3cb38] DEBUG - [HCl#535b] HTTP requesting GET http://192.168.1.2:8080/upnp
Aug 02, 2023 21:27:39.533 [0x7f5669819b38] DEBUG - [HttpClient/HCl#535b] HTTP/1.1 (0.0s) 404 response from GET http://192.168.1.2:8080/upnp
Aug 02, 2023 21:27:39.533 [0x7f5667d3cb38] ERROR - SSDP: Error parsing device schema for http://192.168.1.2:8080/upnp
Aug 02, 2023 21:28:45.240 [0x7f5652375b38] DEBUG - [Req#2bc8e0/ViewStateSync] Starting
Aug 02, 2023 21:28:45.240 [0x7f5652375b38] DEBUG - [Req#2bc8e0/ViewStateSync] Got token for user 1 (mgohring)
Aug 02, 2023 21:28:45.241 [0x7f5652375b38] DEBUG - [Req#2bc8e0/ViewStateSync] Starting for user 1
Aug 02, 2023 21:28:45.241 [0x7f5652375b38] DEBUG - [Req#2bc8e0/ViewStateSync] Sending state
Aug 02, 2023 21:28:45.241 [0x7f5652375b38] DEBUG - [Req#2bc8e0/ViewStateSync] All state sent
Aug 02, 2023 21:28:45.241 [0x7f5652375b38] DEBUG - [Req#2bc8e0/ViewStateSync] Getting state
Aug 02, 2023 21:28:45.241 [0x7f5652375b38] DEBUG - [Req#2bc8e0/ViewStateSync/HCl#535c] HTTP requesting GET https://scrobbles.plex.tv/state/13960898?after=MTY5MDkwNTUyNTY3OC02NGM5MmJiNTdhMzY5MzVjN2I2YjM0MDg%3D&count=100
Aug 02, 2023 21:28:45.358 [0x7f5669819b38] DEBUG - [HttpClient/HCl#535c] HTTP/2.0 (0.1s) 200 response from GET https://scrobbles.plex.tv/state/13960898?after=MTY5MDkwNTUyNTY3OC02NGM5MmJiNTdhMzY5MzVjN2I2YjM0MDg%3D&count=100
Aug 02, 2023 21:28:45.359 [0x7f565470ab38] DEBUG - [Req#2bc8e0/ViewStateSync] Reading 0 states
Aug 02, 2023 21:28:45.359 [0x7f565470ab38] DEBUG - [Req#2bc8e0/ViewStateSync] Done getting states
Aug 02, 2023 21:28:45.359 [0x7f565470ab38] DEBUG - [Req#2bc8e0/ViewStateSync] Finished
Aug 02, 2023 21:31:25.504 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:31:25.504 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=6, flags=0x1803, change=0x0
Aug 02, 2023 21:31:25.504 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:31:25.504 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:31:25.505 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:31:25.575 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:31:25.575 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=4, flags=0x1843, change=0x0
Aug 02, 2023 21:31:25.575 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:31:25.575 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:31:25.597 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:31:25.597 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:31:25.597 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=6, flags=0x1803, change=0x0
Aug 02, 2023 21:31:25.597 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:31:25.597 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:31:25.897 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:31:25.897 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=3, flags=0x1843, change=0x0
Aug 02, 2023 21:31:25.897 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:31:25.897 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:31:25.919 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:31:25.919 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:31:25.919 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=5, flags=0x1843, change=0x0
Aug 02, 2023 21:31:25.919 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:31:25.919 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:31:25.920 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:31:26.494 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:31:26.494 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=4, flags=0x1803, change=0x0
Aug 02, 2023 21:31:26.494 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:31:26.494 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:31:26.494 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:31:26.494 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1400, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:31:26.494 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=7, flags=0x1403, change=0x0
Aug 02, 2023 21:31:26.494 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=3, flags=0x1803, change=0x0
Aug 02, 2023 21:31:26.494 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=5, flags=0x1803, change=0x0
Aug 02, 2023 21:31:26.496 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:31:29.166 [0x7f5652375b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:31:29.414 [0x7f5653987b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:31:34.167 [0x7f5652375b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:31:34.414 [0x7f5655227b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:31:37.748 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Failure: 125 - Operation canceled.
Aug 02, 2023 21:31:37.748 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] MyPlex: We appear to have lost Internet connectivity, resetting device URL cache.
Aug 02, 2023 21:31:37.749 [0x7f566bc2db38] ERROR - [EventSourceClient/pubsub/172.105.96.32:443] Retrying in 15 seconds.
Aug 02, 2023 21:31:39.168 [0x7f5653987b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:31:39.415 [0x7f5652375b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:31:41.545 [0x7f5652375b38] DEBUG - NetworkServiceBrowser: SSDP departed after not being seen for 21.951433 seconds: 192.168.1.1 (UGW3)
Aug 02, 2023 21:31:41.545 [0x7f5652375b38] DEBUG - NetworkServiceBrowser: SSDP departed after not being seen for 21.951467 seconds: 192.168.1.1 (WANDevice)
Aug 02, 2023 21:31:41.545 [0x7f5652375b38] DEBUG - NetworkServiceBrowser: SSDP departed after not being seen for 21.951480 seconds: 192.168.1.1 (WANConnectionDevice)
Aug 02, 2023 21:31:44.169 [0x7f5655227b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:31:44.416 [0x7f5652375b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:31:49.170 [0x7f5652375b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:31:49.417 [0x7f565470ab38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:31:51.546 [0x7f5652375b38] DEBUG - NetworkServiceBrowser: SSDP departed after not being seen for 29.824435 seconds: 192.168.1.36 (Philips hue (192.168.1.36))
Aug 02, 2023 21:31:51.546 [0x7f5652375b38] DEBUG - NetworkServiceBrowser: SSDP departed after not being seen for 28.549707 seconds: 192.168.1.225 (Roku Ultra)
Aug 02, 2023 21:31:51.546 [0x7f5652375b38] DEBUG - NetworkServiceBrowser: SSDP departed after not being seen for 28.185767 seconds: 192.168.1.237 (Roku Player)
Aug 02, 2023 21:31:52.753 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Resolving 172.105.96.32 port 443
Aug 02, 2023 21:31:52.753 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Resolved 172.105.96.32 to 172.105.96.32:443
Aug 02, 2023 21:31:52.753 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:31:52.753 [0x7f566be30b38] ERROR - [EventSourceClient/pubsub/172.105.96.32:443] Retrying in 30 seconds.
Aug 02, 2023 21:31:54.170 [0x7f5652375b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:31:54.418 [0x7f5655227b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:31:59.170 [0x7f5655227b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:31:59.419 [0x7f5653987b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:04.171 [0x7f5652375b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:04.419 [0x7f5655227b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:09.172 [0x7f5655227b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:09.420 [0x7f5653987b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:14.172 [0x7f565470ab38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:14.421 [0x7f5652375b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:19.173 [0x7f5653987b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:19.422 [0x7f565470ab38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:22.756 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Resolving 172.105.96.32 port 443
Aug 02, 2023 21:32:22.756 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Resolved 172.105.96.32 to 172.105.96.32:443
Aug 02, 2023 21:32:22.756 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:32:22.756 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443/PubsubServerManager/getNextWorkingHost/yyz] 2 total hosts available in region, starting tests
Aug 02, 2023 21:32:22.757 [0x7f566bc2db38] DEBUG - [EventSourceClient/connectiontester/172.105.99.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:32:22.757 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443/PubsubServerManager/getNextWorkingHost/yyz] Switching to next host in region: 172.105.99.32
Aug 02, 2023 21:32:22.758 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Stopping.
Aug 02, 2023 21:32:22.759 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Resolving 172.105.99.32 port 443
Aug 02, 2023 21:32:22.760 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Resolved 172.105.99.32 to 172.105.99.32:443
Aug 02, 2023 21:32:22.760 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:32:22.760 [0x7f566bc2db38] ERROR - [EventSourceClient/pubsub/172.105.99.32:443] Retrying in 15 seconds.
Aug 02, 2023 21:32:24.174 [0x7f565470ab38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:24.424 [0x7f5653987b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:29.175 [0x7f5653987b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:29.425 [0x7f5655227b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:34.176 [0x7f5655227b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:34.425 [0x7f565470ab38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:37.768 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Resolving 172.105.99.32 port 443
Aug 02, 2023 21:32:37.769 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Resolved 172.105.99.32 to 172.105.99.32:443
Aug 02, 2023 21:32:37.769 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:32:37.769 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443/PubsubServerManager/getNextWorkingHost/yyz] 2 total hosts available in region, starting tests
Aug 02, 2023 21:32:37.769 [0x7f566be30b38] DEBUG - [EventSourceClient/connectiontester/172.105.96.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:32:37.770 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443/PubsubServerManager/getNextWorkingHost/yyz] Switching to next host in region: 172.105.96.32
Aug 02, 2023 21:32:37.770 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Stopping.
Aug 02, 2023 21:32:37.771 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Resolving 172.105.96.32 port 443
Aug 02, 2023 21:32:37.775 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Resolved 172.105.96.32 to 172.105.96.32:443
Aug 02, 2023 21:32:37.775 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:32:37.775 [0x7f566bc2db38] ERROR - [EventSourceClient/pubsub/172.105.96.32:443] Retrying in 15 seconds.
Aug 02, 2023 21:32:39.177 [0x7f565470ab38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:39.426 [0x7f5653987b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:44.177 [0x7f5653987b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:44.427 [0x7f5655227b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:49.178 [0x7f5652375b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:49.428 [0x7f565470ab38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:52.781 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Resolving 172.105.96.32 port 443
Aug 02, 2023 21:32:52.781 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Resolved 172.105.96.32 to 172.105.96.32:443
Aug 02, 2023 21:32:52.781 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:32:52.781 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443/PubsubServerManager/getNextWorkingHost/yyz] 2 total hosts available in region, starting tests
Aug 02, 2023 21:32:52.781 [0x7f566be30b38] DEBUG - [EventSourceClient/connectiontester/172.105.99.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:32:52.781 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443/PubsubServerManager/getNextWorkingHost/yyz] Switching to next host in region: 172.105.99.32
Aug 02, 2023 21:32:52.782 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Stopping.
Aug 02, 2023 21:32:52.782 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Resolving 172.105.99.32 port 443
Aug 02, 2023 21:32:52.783 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Resolved 172.105.99.32 to 172.105.99.32:443
Aug 02, 2023 21:32:52.783 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:32:52.783 [0x7f566bc2db38] ERROR - [EventSourceClient/pubsub/172.105.99.32:443] Retrying in 15 seconds.
Aug 02, 2023 21:32:54.179 [0x7f5655227b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:54.429 [0x7f5653987b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:59.179 [0x7f565470ab38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:32:59.430 [0x7f5652375b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:33:04.180 [0x7f5653987b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:33:04.430 [0x7f5652375b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:33:07.791 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Resolving 172.105.99.32 port 443
Aug 02, 2023 21:33:07.792 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Resolved 172.105.99.32 to 172.105.99.32:443
Aug 02, 2023 21:33:07.792 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:33:07.792 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443/PubsubServerManager/getNextWorkingHost/yyz] 2 total hosts available in region, starting tests
Aug 02, 2023 21:33:07.792 [0x7f566bc2db38] DEBUG - [EventSourceClient/connectiontester/172.105.96.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:33:07.792 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443/PubsubServerManager/getNextWorkingHost/yyz] Switching to next host in region: 172.105.96.32
Aug 02, 2023 21:33:07.793 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Stopping.
Aug 02, 2023 21:33:07.794 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Resolving 172.105.96.32 port 443
Aug 02, 2023 21:33:07.795 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Resolved 172.105.96.32 to 172.105.96.32:443
Aug 02, 2023 21:33:07.795 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:33:07.795 [0x7f566bc2db38] ERROR - [EventSourceClient/pubsub/172.105.96.32:443] Retrying in 15 seconds.
Aug 02, 2023 21:33:09.182 [0x7f5655227b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:33:09.431 [0x7f565470ab38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:33:14.182 [0x7f565470ab38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:33:14.431 [0x7f5652375b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:33:19.183 [0x7f5653987b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:33:19.432 [0x7f5655227b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:33:22.798 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Resolving 172.105.96.32 port 443
Aug 02, 2023 21:33:22.798 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Resolved 172.105.96.32 to 172.105.96.32:443
Aug 02, 2023 21:33:22.799 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:33:22.799 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443/PubsubServerManager/getNextWorkingHost/yyz] 2 total hosts available in region, starting tests
Aug 02, 2023 21:33:22.799 [0x7f566be30b38] DEBUG - [EventSourceClient/connectiontester/172.105.99.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:33:22.799 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443/PubsubServerManager/getNextWorkingHost/yyz] Switching to next host in region: 172.105.99.32
Aug 02, 2023 21:33:22.800 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Stopping.
Aug 02, 2023 21:33:22.800 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Resolving 172.105.99.32 port 443
Aug 02, 2023 21:33:22.802 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Resolved 172.105.99.32 to 172.105.99.32:443
Aug 02, 2023 21:33:22.802 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:33:22.802 [0x7f566bc2db38] ERROR - [EventSourceClient/pubsub/172.105.99.32:443] Retrying in 15 seconds.
Aug 02, 2023 21:33:24.184 [0x7f565470ab38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:33:24.433 [0x7f5655227b38] WARN - NetworkServiceBrowser: Error sending out discover packet from 192.168.1.11 to 192.168.1.255: Network unreachable
Aug 02, 2023 21:33:28.713 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:28.713 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=5, flags=0x11843, change=0x0
Aug 02, 2023 21:33:28.713 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:28.713 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:28.714 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:28.782 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:28.782 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=5, flags=0x11843, change=0x0
Aug 02, 2023 21:33:28.782 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:28.782 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:28.782 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:28.782 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=6, flags=0x11843, change=0x0
Aug 02, 2023 21:33:28.783 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:28.783 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1448, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:28.783 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=7, flags=0x11443, change=0x0
Aug 02, 2023 21:33:28.783 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:28.783 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:28.856 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:28.856 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=4, flags=0x11843, change=0x0
Aug 02, 2023 21:33:28.856 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:28.856 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:28.857 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:28.899 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:28.899 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=3, flags=0x11843, change=0x0
Aug 02, 2023 21:33:28.899 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:28.899 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:28.899 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:30.890 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:30.890 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=5, flags=0x11843, change=0x0
Aug 02, 2023 21:33:30.890 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:30.890 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:30.891 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:32.392 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:32.392 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=3, flags=0x11843, change=0x0
Aug 02, 2023 21:33:32.392 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:32.392 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:32.393 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:32.393 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:32.393 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=4, flags=0x11843, change=0x0
Aug 02, 2023 21:33:32.393 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:32.393 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:32.393 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=5, flags=0x11843, change=0x0
Aug 02, 2023 21:33:32.395 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:32.395 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:32.395 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=6, flags=0x11843, change=0x0
Aug 02, 2023 21:33:32.395 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:32.395 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:34.919 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:34.919 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=6, flags=0x1803, change=0x0
Aug 02, 2023 21:33:34.919 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:34.919 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:34.920 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:34.996 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:34.996 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=6, flags=0x1803, change=0x0
Aug 02, 2023 21:33:34.996 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:34.996 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:35.004 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:35.303 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:35.303 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=3, flags=0x1843, change=0x0
Aug 02, 2023 21:33:35.303 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:35.303 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:35.331 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:35.332 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:35.332 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=4, flags=0x1843, change=0x0
Aug 02, 2023 21:33:35.332 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:35.332 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:35.332 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:35.332 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=5, flags=0x1843, change=0x0
Aug 02, 2023 21:33:35.333 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:35.914 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:35.914 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=3, flags=0x1803, change=0x0
Aug 02, 2023 21:33:35.914 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:35.914 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:35.914 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:35.915 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=4, flags=0x1803, change=0x0
Aug 02, 2023 21:33:35.915 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:35.915 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:35.915 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:35.915 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:35.915 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=5, flags=0x1803, change=0x0
Aug 02, 2023 21:33:36.915 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1400, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:36.915 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=7, flags=0x1403, change=0x0
Aug 02, 2023 21:33:36.915 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:36.915 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:36.916 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:37.810 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Resolving 172.105.99.32 port 443
Aug 02, 2023 21:33:37.810 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Resolved 172.105.99.32 to 172.105.99.32:443
Aug 02, 2023 21:33:37.811 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:33:37.811 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443/PubsubServerManager/getNextWorkingHost/yyz] 2 total hosts available in region, starting tests
Aug 02, 2023 21:33:37.811 [0x7f566be30b38] DEBUG - [EventSourceClient/connectiontester/172.105.96.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:33:37.811 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443/PubsubServerManager/getNextWorkingHost/yyz] Switching to next host in region: 172.105.96.32
Aug 02, 2023 21:33:37.813 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.99.32:443] Stopping.
Aug 02, 2023 21:33:37.813 [0x7f566bc2db38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Resolving 172.105.96.32 port 443
Aug 02, 2023 21:33:37.813 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Resolved 172.105.96.32 to 172.105.96.32:443
Aug 02, 2023 21:33:37.813 [0x7f566be30b38] DEBUG - [EventSourceClient/pubsub/172.105.96.32:443] Failure: 101 - Network unreachable.
Aug 02, 2023 21:33:37.813 [0x7f566be30b38] ERROR - [EventSourceClient/pubsub/172.105.96.32:443] Retrying in 15 seconds.
Aug 02, 2023 21:33:38.384 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:38.384 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=4, flags=0x11843, change=0x0
Aug 02, 2023 21:33:38.384 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:38.384 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:38.385 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:38.410 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:38.410 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=3, flags=0x11843, change=0x0
Aug 02, 2023 21:33:38.410 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:38.410 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:38.411 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:38.411 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1448, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:38.411 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=7, flags=0x11443, change=0x0
Aug 02, 2023 21:33:38.411 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:38.411 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:38.427 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:38.427 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=5, flags=0x11843, change=0x0
Aug 02, 2023 21:33:38.427 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:38.427 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:38.428 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
Aug 02, 2023 21:33:38.510 [0x7f5668150b38] DEBUG - NetworkInterface: received Netlink message len=1284, type=RTM_NEWLINK, flags=0x0
Aug 02, 2023 21:33:38.510 [0x7f5668150b38] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=3, flags=0x11843, change=0x0
Aug 02, 2023 21:33:38.510 [0x7f5668150b38] DEBUG - Network change.
Aug 02, 2023 21:33:38.510 [0x7f5668150b38] DEBUG - NetworkInterface: Notified of network changed (force=0)
Aug 02, 2023 21:33:38.511 [0x7f5668150b38] DEBUG - Network change notification but nothing changed.
All of this shows that Plex cannot connect to the Internet / Plex.tv
That actually makes some sense.
Running a unifi system and our cloud key controller had some issues lately. Literally got a new one delivered today.
After it is up and running and if I still have issues like this I’ll post back.
Matt
