Cannot add additional lineup for new tuner (OTA and FIOS)
I have the latest version of PMS running on Windows 10 Pro. I have had an HDHomeRun Connect Quatro connected to the OTA antenna works fine for over a year. I just added an HDHomeRun Prime and it’s connected to Verizon FIOS. When I try to add it to Plex, obviously it has a different channel lineup but Plex only recognizes the original “Broadcast TV OTA Broadcast” channel lineup and does not allow me to add an additional lineup. How do I add another lineup for this tuner?
There can be only one.
If you are not afraid to do some scripting you could create a combined XML file of the two lineups.
The unsanctioned (and who knows what the long term effects would be) is to use two different browsers in incognito mode to remove the dvr then add one tuner and line up in each separate browser.
What is this Highlander? :grin:
Thanks Tiebierius. I would really not want to muck around with custom scripting on this. I would rather be able to have 2 different lineups based on the vast difference between the HDHR units. I am sure the EPG may be confused by the 2 guides and that is probably the reason they are separating it, but I am certain that they could design a method to allow you to chose which EPG you ant to view from with a simple dropdown box. Thanks again.
