weblog.txt (1.2 KB)
Here is my web log
weblog.txt (1.2 KB)
Here is my web log
While debug logging was enabled, were you able to recreate the failure?
It doesn’t look like you have from what was attached. Specifically,
"type": "info",
"host": "app.plex.tv",
"userAgent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.130 Safari/537.36",
"browser": {
"platformVersion": "10",
"isBundled": false,
"isFallback": false,
"relay": false,
It’s not using the Plex/Web loaded from the Synology.
weblog.txt (1.2 KB)
Tried again. Reinstalled Server, accessed URL from inside my Syno.
Literally have no idea what I’m doing at this point.
Forgot an important step.
Sign out of Plex/Web (upper right corner)
Open incognito window
Open http://ip.addr.of.syno:32400/web
As FYI, Server code doesn’t impact what we’re seeing except for the change in bundled app version.
Signed out.
Incognito.
Enabled Debug.
weblog.txt (1.2 KB)
Mine is working right now. Changed nothing…
Also an update of Server Logs
Logs (1).zip (4.0 MB)
I am seeing DNS rebinding protection as active in your logs now. I was looking for this.
In the modem/router, do you have the ability to grant exceptions? (I don’t want to disable it)
If you do, please grant exception for plex.direct private domain. It will greatly speed up the LAN clients and server interaction. Nothing will have to go out to plex.tv and come back.
There is still a plex.tv connectivity issue.
Feb 07, 2020 16:49:18.992 [0x7f6a9530a700] DEBUG - EventSource: Failure in IdleTimeout (0 - Success).
Feb 07, 2020 16:49:18.992 [0x7f6a9530a700] DEBUG - MyPlex: We appear to have lost Internet connectivity, resetting device URL cache.
Feb 07, 2020 16:49:18.992 [0x7f6a94703700] DEBUG - PublicAddressManager: Obtaining public IP.
Feb 07, 2020 16:49:18.992 [0x7f6a9530a700] ERROR - EventSource: Retrying in 15 seconds.
Feb 07, 2020 16:49:18.992 [0x7f6a94703700] DEBUG - HTTP requesting GET http://plex.tv/pms/:/ip
Feb 07, 2020 16:49:22.553 [0x7f6a87a23700] ERROR - Error issuing curl_easy_perform(handle): 28
Feb 07, 2020 16:49:22.553 [0x7f6a87a23700] DEBUG - HTTP simulating 408 after curl timeout
Feb 07, 2020 16:49:22.553 [0x7f6a87a23700] ERROR - Error parsing content.
Feb 07, 2020 16:49:22.553 [0x7f6a87a23700] ERROR - Error parsing XML: Error parsing file.
Feb 07, 2020 16:49:22.553 [0x7f6a87a23700] DEBUG - Media Server: Tested all servers in 0.0 seconds.
Feb 07, 2020 16:49:27.028 [0x7f6a8688f700] ERROR - Error issuing curl_easy_perform(handle): 28
It’s sluggish at best. Which region are you in (i have forgotten) ?
Texas
I added manual DNS Entry for plex.direct
Having lived in the D/FW metro, I know Texas is its own country
but we’ll have to find out why central CONUS isn’t responding.
There are Plex folks in Austin.
I have questions into the web app team now.
Trying to find out what was changed in client-server interaction because this is too profound a departure from norm.
Thanks for the update, and thanks for your help.
Going to provide back story in case it might be helpful.
Back Story:
Established Synology NAS with Plex for 4+ years.
I upgraded ISP service virtually at the exact same time as the outage on 02/06/20.
Old Router/Modem: Coaxial WAN. >>> New Router: Ethernet WAN.
I use Google Wifi sytem as my main LAN interface. I wanted to dump the router and go straight to Google Wifi.
I removed the router and added a Netgear Unmanaged switch.
ISP > Google Wifi > Netgear Switch > Synology NAS > Plex Media Server
Never got Plex working.
Apparently, unmanaged switches don’t handle DCHP servers!?
I switched everything BACK to Frontier (ISP) Router and added port forward.
Uninstalled/reinstalled plex server about 6-10 times.
At one point I was able to access plex from my phone but NOT the web?!?!
Deleted Plex server from devices on web app, expecting it to refresh/reappear.
Thats about all I can think of.
Thanks again.
If I may make a few corrections?
Now, what has changed? Where is the DHCP server?
Any thoughts on my log issue?
Current setup (since joining this thread):
ISP > Frontier Router > Synology > PMS
Can you grab the logs as they stand now, without purging any of the older logs.
(total log usage for all logs is only 64MB)
I was unable to access my Plex Server on my NAS as well. Reinstalling Plex and restarting appears to have fixed it for me.
So I did what you wrote yesterday.
Result is the same, problem remains. At my Samsung TV I only get a view with circles behind my mapnames. Although there seems to be some progress, because I could watch a movie. But at the other hand I couldn’t open the menu to see the remaining movie time, the buttons to play fast forward and other things.
I use version 1.18.5.2309. I uploaded a log file, don’t know if this is the right file, because this is 3.1 MB and the others I see were only a few kB ![]()
Sure, here they are. I installed an older version to see if I would have better success. UnfortunatelyLogs.zip (197.6 KB) , I have not.
