Cannot have secure connections
Server Version#: 1.28.1.6104
Player Version#: app.plex.tv (but others too)
Hello. I cannot securely connect my plex clients to my plex server. I’ve seen that this is a somewhat regular problem but I’ve tried a lot of things that were mentioned and can’t seem to solve that. Here is a plan of my home network. To be clear, I don’t want to setup remote access. I only want secure connections throughout my local network
ISP Modem (WiFi deactivated)
TP-Link Archer AX-50 router (does my Wifi) — WiFi peripherals
Basic 8-port switch (cannot be managed) — ethernet peripherals, among them the PC with plex server
What I tried so far, without success
• UPNP is activated on the modem and on the Archer
• The Archer router is the only thing connected to the ISP modem. It has a fixed IP (192.168.1.11).
• The PCs with server and client have fixed IP in the same sub network (10.33.21.xx).
• I tried to deactivate the Archer firewall
• I tried to connect my clients via ethernet, both on the switch, on the router, and on the modem directly. Via WiFi too. Same message all the time.
• I tried several different clients (Windows, Linux, Mac, Android : all say the same thing)• I tried different servers : Windows & Linux.
• I forwarded port 32400 to my Archer router from the modem, and from the Archer to my plex server. No success.
• I setup my router in bridge mode, having only one NAT (knowing double NAT might be a problem) by the Archer, no success.
Anyone has an idea ?
Thanks !
PS : Plex clients do not tell specific error messages besides “cannot connect securely”. Everything works well if I allow unsecure connections. But for the sake of understanding things I’d rather make this work securely.
I don’t know if this is relevant but when I try to go from Firefox to my server :
https://10.33.21.20:32400 I have the following error message about certificates.
Les sites web justifient leur identité par des certificats. Firefox ne fait pas confiance à ce site, car il utilise un certificat qui n’est pas valide pour 10.33.21.20:32400. Le certificat n’est valide que pour *.e63c73bfcd204a2fbf2b93dde053c524.plex.direct.
Code d’erreur : SSL_ERROR_BAD_CERT_DOMAIN
Sorry it’s in French, basically it says : Firefox doesn’t trust this site because the cert is invalid for …, it is only valid for…
Secure connections failing in the local network of the server is not a matter of UPnP or port forwarding.
It has to do with a security feature which is employed by many “DNS resolvers”. (Your router has also such a DNS resolver in it.)
The feature is called “DNS rebinding protection” and prohibits the assignment of a domain name to a device in the local network (namely your Plex server). But that is exactly what is necessary for secure connections.
The only solution is to either
  • live without secure connections
  • use a different router without DNS rebinding protection
  • use a router which allows customization of this protection feature. Setting the domain plex.direct onto the list of domains for which this protection is disabled.
Background info here: How to Use Secure Server Connections | Plex Support
Thank you. It seems that there is no way to customize this in the TP Link Archer AX-50 so I’ll go for unsecure connections. It’s all on a private secured network so I don’t mind, I just wanted to make this work out of frustration…
If anybody managed to make this work with a TP Link Archer AX-50 or close, let me know !
If you employ a second DNS server on your network (a Pi-hole, or a pfsense appliance for instance) you can delegate all DNS tasks away from your router. And the Pi-hole uses an open source DNS resolver which certainly does support the necessary configuration option.
Thanks. I was also thinking about flashing my router with OpenWRT (which provides whitelist for DNS rebinding protection) but my model is not OpenWRT compatible. Too bad ! Well I’ll go for unsecure connections, since it’s all local it doesn’t really matter. I spend way too much time on this but I learnt a lot of things, thank you.
