Since build 12814 I cannot open the first season or the 7th and 8th season or the ninth season of the next row to see the individual episodes. This works fine with the release build. It does not matter what tv program I pick. The the first box will not open nor the 7th and 8th and the 9th on the next row.
Only happens in landscape mode.
I have the same problem but only apparently with season 1 on my iPad Pro 12.9 .
Art
Edit: it’s actually worst than this. See next entry on this thread.
After some investigation, happens on both landscape and portrait orientation I’m my iPad Pro 12.9. And example with a series with 11 seasons:
In portrait mode:
Left and right most season of every line are unselectable.
In this screen, season 0 (specials), season 5 and season 6 are all unselectable.
In landscape mode:
Season 0 (specials), season 1, season 6, season 7 and on the second line season 8 and season 9 are all unselectable.
This is with the latest build as of now (12814)
You CAN navigate to the unselectable seasons by the roundabout way of going to another of the selectable seasons and clicking on the “season” link there and then selecting the one you want to go to.
I also checked with the current release version and that one does not exhibit this problem.
Mine is an iPad pro 9.7. Portrait mode is working fine to select any season on multiple lines. In landscape it is the left most box and the two right most boxes.
What build are you running?
Edit: never mind, saw it’s the same build as mine.
I just got the iPad 12.9, previously I had an iPad Pro 9.7 and on a previous build I remember a similar problem, but didn’t bother to report as I actually noticed it minutes before activating the new iPad.
Art
Thanks for reporting! We’re working on a fix
Build 12851 should fix the issue, sorry for the inconvenience!
@sergiou87 , yes indeed, it’s working properly again. Thanks!
