Cannot Play MKV after update
may I have those logs please?
ok i cleared the codecs folder again.
tried to play a video that gives an error. it gave an error.
tried playing 1 that does work and it downloaded the codecs and then started to play.
i then tried another one that gives an error and it still gave the same error.
(File removed)
This server has attempted to download the codecs so many times now that it’s throttled by Plex.tv (limit is 30 times per day) – ERROR 429
Nov 06, 2020 20:31:12.812 [0x7fa52ffff700] DEBUG - Auth: authenticated user 1 as rcash88
Nov 06, 2020 20:31:12.813 [0x7fa4feffd700] DEBUG - Request: [172.17.0.1:36608 (Subnet)] GET / (11 live) Signed-in Token (rcash88)
Nov 06, 2020 20:31:12.818 [0x7fa52ffff700] DEBUG - Completed: [172.17.0.1:36608] 200 GET / (11 live) 5ms 6928 bytes (pipelined: 1)
Nov 06, 2020 20:31:13.107 [0x7fa4c1ffb700] DEBUG - [Transcode] HTTP 429 response from GET https://plex.tv/api/codecs/easyaudioencoder?build=linux-x86_64-standard&deviceId=35250b0a-607e-4db6-beb4-5524b73739f3&oldestPreviousVersion=legacy&version=798
Nov 06, 2020 20:31:13.108 [0x7fa4c1ffb700] ERROR - [Transcode] Codecs: Failed to download XML for codec 'easyaudioencoder'
Nov 06, 2020 20:31:13.108 [0x7fa4c1ffb700] ERROR - [Transcode] Error configuring transcoder: Decoder install failed: eac3_eae
Nov 06, 2020 20:31:13.108 [0x7fa4c1ffb700] DEBUG - [Transcode] Streaming Resource: Terminating session 0x7fa4e01a3b90:r8js8d37e59m4ukhf24k4o2o which is using transcoder slot.  Used slots is now 0
Nov 06, 2020 20:31:13.108 [0x7fa4c1ffb700] DEBUG - [Transcode] Streaming Resource: Terminated session 0x7fa4e01a3b90:r8js8d37e59m4ukhf24k4o2o with reason Conversion failed. A required codec could not be found or failed to install.
Nov 06, 2020 20:31:13.109 [0x7fa4fe7fc700] DEBUG - [Transcode] Killing job.
Nov 06, 2020 20:31:13.109 [0x7fa4fe7fc700] DEBUG - [Transcode] Job was already killed, not killing again.
Nov 06, 2020 20:31:13.109 [0x7fa4fe7fc700] DEBUG - [Transcode] Stopping transcode session bk65hjnq3dqfzy3vrqz3jnk9
Nov 06, 2020 20:31:13.109 [0x7fa4fd7fa700] DEBUG - [Transcode] Cleaning directory for session bk65hjnq3dqfzy3vrqz3jnk9 (/transcode/Transcode/Sessions/plex-transcode-bk65hjnq3dqfzy3vrqz3jnk9-cae159b9-cd5a-4c42-892d-d7dba5dd49a5)
You need to let it clear the timeout on its own. This is not something I can manually clear for you, sorry.
