Can't add add'l episodes to extsting TV library
I have an existing TV library with one show/4 seasons. Season 1 won’t load correctly even though I think I have it title formatted correctly…after all the other 3 seasons loaded fine. The problem is that episodes 1 and 2 are one 2 part episode. It doesn’t load at all. Then episode 3 loads as episode 1, all following episodes are incorrectly numbered, and the last 2 episodes aren’t even titled. Can someone look at my file list and show me what I have done incorrectly?hammer1
it looks like the show is organized differently on your source than what TheTVDb.com expects…
There, More Than Murder is a special, while season 1 has only 10 episodes, starting with 24 Karat Dead.
Mickey Spillane's Mike Hammer - TheTVDB.com.
How to Fix it…
  • Adjust your filenames to match the organization from TheTVDb.com
    • Move the episodes of More Than Murder into a Specials/Season 00 folder and rename them accordingly. As TheTVDb.com considers this a single episode special, you’ll need to either merge the two files (e.g .using MKVToolNix) or combine them for Plex by adding -pt1/-pt2 to the file names (replacing the (1)/(2) suffix!)
      TV Shows
      .. > Mickey Spillane's Mike Hammer
      .. .. > Specials
      .. .. .. > Mickey Spillane's Mike Hammer - s00e02 - More Than Murder-pt1.ext
      .. .. .. > Mickey Spillane's Mike Hammer - s00e02 - More Than Murder-pt2.ext
    • Renumber the remaining episodes of season 1 to match season 1 @ TheTVDb.com
additional remark…
you might want to include the year the show was released in your folder / episode names… otherwise Plex might confuse it with the 1958 version of that show.
Example:
Mickey Spillane's Mike Hammer (1983) > Season 01 > Mickey Spillane's Mike Hammer (1983) - s01e01 - 24 Karat Dead.ext
Thanks so much for the explanation, tom80H. There was a pilot movie that I handled as below with “S00E01” and PLEX handled it as a Special. There was also a special episode in season 3 that I handled as “S03E00” and it worked fine. I don’t understand exactly why PLEX didn’t handle this season 1 situation, but now, thanks to your instructions, I know how to fix it. hammer1 hammer1a hammer3 hammer3a
Plex will always scan properly formatted files – however in case of the season 3 special you can see it doesn’t get matching metadata from its online source.
“The Return of Mickey Spillane’s Mike Hammer” is listed on TheTVDb.com as s00e03 – however there’s not much to find (except for the title and air date).
Thanks to your help, I’ve now got my Mike Hammer library all set up just right! Happy New Year!
