Can't add ErsatzTV XMLTV guide to ErsatzTV tuner
Server Version#: 1.32.7.7621
Tuner Make/Model: ErsatzTV
Using XMLTV?: I really want to!
I’ve read the Plex user guide to add your own XMLTV to a DVD tuner but it seems to be out of date. I added my ErsatzTV tuner today and where I would enter my postal code there is no option to add my own XMLTV guide. Where has this setting moved to? I cannot find it anywhere.
Do you already have a DVR and tuner configured? Or is this a completely new configuration? If you have an existing DVR using Plex’s guide data you cannot add a second which uses XMLTV; the two can’t be mixed.
I do have other tuners for live TV that use Plex’s epg, but this is a new tuner set up. Are you saying that if one tuner uses Plex all tuners have to use Plex?
Yes. But also, if one tuner uses XMLTV, all tuners have to use XMLTV. That is, they are mutually-exclusive.
Edit:
Here’s a relevant feature suggestion. You may want to vote and comment there.
Well that’s annoying.
Thanks for the info! I’ll look into that.
